10 speed chain ring...
[Closed] 10 speed chain ring on XT 9 speed triple ring chain set ?
[#7923994]
I've got an XT 9 speed Hollowtech II chain set. Is it possible to run a 10 speed chain ring successfully if I change the cassette, chain and rear mech of course ? Do I need spacers ?
Posted : 03/07/2016 9:07 pm
It'll work no bother, you'll just need shorted chain ring bolts
Posted : 03/07/2016 9:59 pm
If it doesn't fit, all that should need doing is a small about if filing, to remove the excess from the chain bolt tabs
Posted : 03/07/2016 10:09 pm
Cheers guys, many thanks for the positive advice
Posted : 05/07/2016 8:22 pm
M770 9 speed will be fine as it came with the later metal + composite middle ring. The older m760 type will need some fettling for the new style middle chain rings.
Posted : 05/07/2016 9:09 pm
Thanks Andy. Bad news then as I think mine is the older one !
Posted : 05/07/2016 9:29 pm
