1 x 9 chain length
[Closed] 1 x 9 chain length
[#2120348]
Just putting the final touches to my new bike and the chain is the last thing to go on. I know that it's round the two biggest rings for a 3 x 9 with no deraileur but what is the correct method of measuring chain length for a 1 x 9?
Thanks!
Posted : 24/10/2010 5:59 pm
big to big, not thru the mech, add 2 links
Posted : 24/10/2010 6:06 pm
Thank TJ. Running a Stinger for the first time too. Does this affect things?
Posted : 24/10/2010 6:08 pm
No idea. does it alter the chain run?
Posted : 24/10/2010 6:15 pm
I'd run it through the Stinger, as it will (very, very slightly) shorten your chain, as it adds tension, then as TJ says, 'big to big and add 2 links'.
Posted : 24/10/2010 7:32 pm
 DeeW
Stinger's actually going to lengthen the chain as with the Stinger on the chain won't take the shortest (straight) route from chainring to rear mech [God I must be bored to have bothered to write that!]
Posted : 24/10/2010 8:15 pm
i run a 36 tooth race face front, with bashguard.
keep the chain as short as possible, really stretch the rear mech out, as long as it changes; keep it tight.
may be worth looking at a short cage mech; road style. in the old days downhillers used road cassettes and mechs. this made for a smoother transition, there was always a sharp drop between some of the lower gears
this may be feasible if your ran a 32 front and maybe bodged if possible a 10 tooth rear?
Posted : 24/10/2010 10:58 pm
36T with an 11-34 cassette. Cut it now and fitted. Seems OK, will give an initial indexing, short ride and get back to you. Thanks for the replies.
Posted : 24/10/2010 11:06 pm
