1 x 11 chain tensio...
[Closed] 1 x 11 chain tension
[#10972615]
Hi folks just converted my super x cross bike to 1 x, 40t hope ring and 11- 42 cassette, apex shifters and rear mech. Only removed one link from 114 sram red chain and it seems about right but how do you know.... set up loads of 2 and 3x over the years but first venture into single ring territory 🙄
Posted : 21/12/2019 10:05 am
I had this problem as all the formula I could find were for multiple chain rings. In the end I just moved the mech into largest rear cog and stuck the on at a length that seemed not too stretch the mech to it's full extent. It's been fine.
Posted : 21/12/2019 12:26 pm
Get it so the mech is at about 45deg to the chainstay when in the lowest gear.
Posted : 21/12/2019 12:28 pm
The mech body Steve or the cage with the two pulleys?
Posted : 21/12/2019 2:00 pm
Cheers folks... pretty much what I did, plus it looks about 45 degrees too so guessing it'll be ok ...thanks all😊
Posted : 21/12/2019 3:16 pm
The whole thing so end to end it kind of forms a 45deg angle overall
Posted : 21/12/2019 3:23 pm
I've always gone with threading the chain around chainring and biggest cog (but not through the derailleur), allowing extra chain until I get to the next inner link then removing two links. This leaves the chain with an inner link at either end that get connected with the quick/master link.
Posted : 21/12/2019 4:24 pm
Big-big plus two links is pretty failsafe. You definitely don't want it any shorter than that. Why would you want it any longer?
Posted : 21/12/2019 5:01 pm
Whoops! Made a mistake in my last post, should have been "add two links" not remove. Doh!
Posted : 21/12/2019 5:33 pm
