1 x 10 wide range c...
[Closed] 1 x 10 wide range cassette - Sunrace?
[#9438134]
I'm currently set up with a 1x10 11-32 cassette, and 32 NW front ring. Without going to the extra expense of a 1x11 set up (new hubs/shifters/derailleurs etc...), I was looking at wider range cassettes.
Sunrace MX3 with 11-40 or 11-42? Can't see any reason not to. Expander cogs are a cheaper option, but that'll mean a massive jump from the current bottom cog. The Sunrace has a 36 as the #2 cog to give a better spread.
Who's been using one? any problems with a Sram set up?
Posted : 16/07/2017 6:50 am
using an 11-40 with no issues whatsover. Recommend.
(you could get an 11-36 i.o your 11-32, if you need wider range but don't need to go right to a 40/42. But it's a new cassette either way, and prob chain too, the 40's only one cog and I use mine 'rarely' but like having it there for when I do)
Posted : 16/07/2017 6:53 am
I went from 2x10 earlier this year to 1x using a Sunrace MX3 11-42 with a SRAM X9 - shifts perfectly, do it! 😀
Posted : 16/07/2017 7:11 am
Running two of them, shift very well and no issues.
Posted : 16/07/2017 7:15 am
Thanks all, helps me make up my mind.
@thwapy - X9 also, so reassured.
I live in the Durham Dales, so no massive hills or long steep ascents, so the widest of ranges currently available aren't really needed.
Posted : 16/07/2017 8:25 am
11-42 has been great for me, see with a rad cage
Posted : 16/07/2017 8:38 am
Minor point but you don't need new hubs for 1x11.
Posted : 16/07/2017 8:39 am
not even a front one Gromit?
Posted : 16/07/2017 8:52 am
Sunrace 11/42 here with a Goatlink on a Solaris, recommended.
Posted : 16/07/2017 9:30 am
@nixie - Ah? I'm not fully up to speed on all this then.
So there are 11 speed cassettes out there that will fit my current Sram 10 speed freehub? I thought I'd need to go to an XD, or similar, or is that just for Sram cassettes?
Posted : 16/07/2017 10:21 am
It's only if you want a 10t smallest sprocket. If you're happy with 11t smallest sprocket then Sram, Shimano, Sunrace and others have options that are designed to work on a 10spd freehub body.
Posted : 16/07/2017 10:24 am
