1" headset ram...
[Closed] 1" headset rambling silly question.
[#1614269]
Doing up an old bike for a friend. Has a Judy elastomer 1" threaded fork circa 97 - I think. Can I fit any non threaded 1" fork if I get a 1" threadless headset too? Not sure where to get one though. The other option is to fit one of those adaptor things. Just a little bit nervous of quill stems - not sure if this is a rational fear though.
Posted : 16/05/2010 9:50 pm
tange make an inch threadless headset.
Posted : 16/05/2010 9:52 pm
Mmmmmmmm.
Does it have a crown race?
Seriously, you may struggle to find 1" forks or headset. Stick with the threaded, unless you need new forks, in which case go with either. Quill is fine.
Posted : 16/05/2010 9:53 pm
Why are you nervous of quill stems?I don't break them on any of my off road bikes including the inch ones on a crosser and 2 mtb's
you will find inch headsets easily as most road bikes had them until not long ago. I last bought one about 6 months ago
Posted : 16/05/2010 9:55 pm
 Sam
Campag ones are nice.
A threadless adapter for threaded fork is just as week as a quill stem anyhow. If you are worried about strength, go threadless. However if you want boing your choice is limited. Loads of nice rigid steel forks with 1" steerers though.
Posted : 16/05/2010 9:57 pm
Rigid steel would be my way of doing it, any links to some?
Posted : 16/05/2010 10:01 pm
Threaded steerers are very different to non-threaded. One is designed to take compression force one direction, the other is designed to for forces in a different direction. (yes, this is a slightly pissed non-techy post). Can you replace the steerer on the fork? Otherwise, use a quill on a threaded, use a aheadset on a non-threaded.
