1 1/8th Threaded he...
[Closed] 1 1/8th Threaded headset problem - Steel Kona
[#2935653]
Hi there,
I've got an old steel Kona which i am attempting to get roadworthy for friend. The headset was missing parts when i bought it, so i've managed to get hold of a new headset (1 1/8th threaded).
This has already been quite a saga, until i was rung yesterday by my local bike shop saying that they don't in fact have tool to fit it! Apparantly my local cycle surgery will, but will probably charge £70!
Does anyone know anywhere in London that can fit this at a reasonable cost, or does anyone know of a way to fit it without the proper tool?
Thanks in advance
Wilf
Posted : 11/07/2011 10:55 pm
long threaded bolt with nut head,2 ruddy great washers larger than the size of the outer cup and a nut on the other end line it up and tighten until snug there are a few diagrams around just google homemade headset tool
Posted : 11/07/2011 10:59 pm
 dobo
like this? works well on my kona but they probably dont have the the spanners or something as they are used to thredless?
[url= http://farm4.static.flickr.com/3017/2792559084_b28ae9be87.jp g" target="_blank">http://farm4.static.flickr.com/3017/2792559084_b28ae9be87.jp g"/> [/img][/url]
[url= http://farm4.static.flickr.com/3104/2791700125_55eba9134c.jp g" target="_blank">http://farm4.static.flickr.com/3104/2791700125_55eba9134c.jp g"/> [/img][/url]
Posted : 11/07/2011 11:04 pm
Just fitted one to my 'new' old GT Timberline - hammer and block of wood for the cups and 36mm open-ended spanner (glad I hung on to that one) for the lock nuts. Sheesh, you could buy a basic headset press and headset spanner for less than £70 😯 . I'm pretty sure that the cups are almost identical regardless of whether it's an older threaded-style or newer ahead-style headset, the only difference being the spanner needed for the locknuts on the older type . . . £70 seems madness!
Posted : 11/07/2011 11:05 pm
Thanks a lot guys,
looks like i'm off to the hardware store tomorrow...!
Will post the results, positive or negative
Posted : 11/07/2011 11:11 pm
The local shops are muppets. It gets installed the same way as a threadless headset.
Posted : 12/07/2011 4:52 am
Cheers Guys,
All sorted now...
Posted : 17/07/2011 11:52 am
