1-1/8 steerer tube ...
[Closed] 1-1/8 steerer tube fork for tapered head tube
[#3627249]
A question please, How do I put 1-1/8" steerer tube to tapered head tube? I plan to buy new bike with tapered headtube and want to put my old fork to it.
Do I need to buy a entirely new headset? what type?
thanks!
Posted : 31/01/2012 12:02 pm
You will need a reducer headset with a reducer bottom cup.
I have one in my Transition Covert, it's an Acros AX-22r
Posted : 31/01/2012 12:03 pm
Depending on the headset fitting of the frame (ask the manufacturer) you can get hope pick and mix cups with a 1 1/8 top cup and a reducer bottom cup, thats what I have in my Kona to fit straight forks into its tapered head tube.
Also think there's a headset finder on the cane creek site that'll tell you what you need if your frame is listed.
Without knowing the frame and what headset it needs no way to advise for sure. But it should be possible. Hope do mix and match if there is not an all in one solution out there.
Posted : 31/01/2012 12:53 pm
My bike is avanti torrent from New Zealand, its not popular in the world (yet I think).. So a bottom reducer right?
Posted : 31/01/2012 8:45 pm
2nd time tonight....
you'll need to know which internal dia the head tube is.
Posted : 31/01/2012 8:58 pm
you need to know if you need a low stack (internal style) or external bearing lower cup or you will mess up the bikes geometry.
Posted : 31/01/2012 11:48 pm
This lists most makes and models of frames and fork types (that I've come across) and makes it a doddle for dumb asses like me to mix and match. Then just search for the cane creek model code. Or hope do the same thing via your lbs.
http://www.canecreek.com/headset-fit-finder
#Edit - you may well just need the top part - which is usually available seperatly.
Posted : 31/01/2012 11:52 pm
Am I missing something but depending on the headset it may just be a case of a new crown race?
If its a cartridge bearing headset you might just need a reducer crown race.
Some of superstar components headsets come with a reduced one as well as one for a tapered steerer.
I also got one on ebay from China or Taiwan, I can't remember
Posted : 01/02/2012 12:58 am
thanks guys
Mine is the zs type..
what about the internal headset and the integrated headset? any significant differences?
Posted : 01/02/2012 7:13 am
Personally, i'd go for a normal tapered headset, and use one of Hope's crown race adaptors on your existing fork. If you buy a reducing headset now, you'll need to replace at least the lower assembly if you swap to a tapered fork in the future, rather than just removing the adaptor(they only add about 2mm to the height, and will work with other headsets too).
Posted : 01/02/2012 9:22 am
Integrated has the bearings directly in the frame.
See here: http://www.parktool.com/blog/repair-help/headset-standards
You've probably got ZS44 upper and ZS49 lower but need to know the lower stack height.
Posted : 01/02/2012 10:12 am
Looking at the website:
http://www.avantibikes.com/trail-dual-suspension/torrent1.aspx?bid=400
Headset: FSA Orbit 1.5E ZS Aheadset 1-1/8" Upper, 1.5" Lower
That is for a tapered fork but it gives us all the specs we need.
It is a low profile lower cup: http://www.fullspeedahead.com/products/292/Orbit-15E-ZS
http://www.fullspeedahead.com/storage/insidetech/items/EN_0457666e-f108-431d-bad1-94f0436e9ad0_Orbit1.5EZS.pdf
Looks like the lower is 56mm not the ZS49.
The superstar ones mentioned above do come with both crown races (tapered or straight) but the lower cup size is wrong: http://superstar.tibolts.co.uk/product_info.php?cPath=25&products_id=426
Your best bet would be the FSA headset the manufacturer uses plus either a reducing crown race is FSA do them or the Hope adapter mentioned above.
Posted : 01/02/2012 10:30 am
Or for hope you want:
http://www.chainreactioncycles.com/Models.aspx?ModelID=70727
on the bottom of the picture E 1.5 Integral 55.9 and the HS136 reducer as coatsey said.
for the top you want number 2 on here:
http://www.chainreactioncycles.com/Models.aspx?ModelID=70725
the 1 1/8 Integral 43.95mm diameter.
Another option is possibly this one which may fit http://www.chainreactioncycles.com/Models.aspx?ModelID=41851
IT comes with a reducing crown race only so later on you would need to source the 1.5" one if you got tapered forks.
For the sake of easy spares and peace of mind I would go for the Hope option as you know you will always be able to get any spares.
Posted : 01/02/2012 10:41 am
Thanks for the details man
I better get one of those hope reducer and use the existing headset, or is there any disadvantage on using this rather than buying a brand new headset?
cheers!
Posted : 03/02/2012 7:02 am
Not unless your existing headset's a bit crap.
Posted : 03/02/2012 8:24 am
