1.0 degree angleset...
[Closed] 1.0 degree angleset for 09 remedy
[#10188098]
Bit of advice please. Having not ridden much in the last couple of years and with a trip to finale ligure in a few weeks i thought it would be a good idea to fish the bike out the shed for a few prep rides. Noticed the headset could proberly do with changing on my 09 trek remedy. Wondered what people’s thoughts are on fitting a 1.0 degree or more? Angleset headset to it. Good idea or not?? Current headset angle is 67 degrees.
Any downsides??
many thanks
eddie
Posted : 24/08/2018 4:00 pm
If you're fitting one you may as well fit a 2 degree one. I had a quick look on the Cane Creek headset tool and it looks like you're in luck - it's a ZS44/56 so you can fit one. You'd need an EC44/ZS56 set up from Works Components or (if you're feeling brave) Superstar.
I'd say it's a good idea, it'll make it feel much more modern and capable.
Posted : 24/08/2018 4:09 pm
Cool thanks was only thinking 1.0 degree in case it didn’t really feel great maybe just settle for the 1.5 degree as a compromise 65.5 sounds good I think. Will go angleset as heard good things about quality
Posted : 24/08/2018 4:14 pm
https://www.superstarcomponents.com/en/slackerizer-angle-headset.htm
There superb quality and £40 with there code on the home page.
Posted : 24/08/2018 5:06 pm
Arent remedy of that age a drop in bearing, like a carbon frame...or am I making that up?
Posted : 24/08/2018 6:25 pm
Not sure but I know it is a zs44/56 as mentioned above
Posted : 24/08/2018 9:52 pm
Breninbeer- I thought that, because my Stache is an integrated headset so I can't fit one to it. Booooo. But the cane creek tool suggests it is ZS44/56 so can take an Angleset .
Posted : 25/08/2018 9:07 am
The bearings in my superstar angleset are alot better than the ones in my works components one. As above go 2 degrees.
Posted : 25/08/2018 3:02 pm
