Hi STW,
Just a little bit of help is needed. on a recent service with replacement seals fitted on the above fork, there is now a little play in the travel. the forks have about 2mm play before it uses the air camber? (it is more negative travel as a top out feeling)any ideas to resolve.
Thank you
Posted : 21/10/2010 12:44 pm
Not the same fork but had the same issue sorted by letting out all the air and repumping a few times.
Posted : 21/10/2010 12:55 pm
I will have a try, but could be be due to no negative air (if so how do you put air in it?
Posted : 21/10/2010 1:00 pm
has anyone else had this issue?
Posted : 21/10/2010 2:13 pm
so just change the air will resolve this
Posted : 22/10/2010 10:53 am
