My mate has some old coil U turn toras and his pretty much lockout when the dial is on full compression damping.Mine Revs however (air) still have an inch of movement when out of the saddle. Is this normal?
thanks
Bill
Have 2 sets of Revs and a set of Pikes...they all pretty much lockout when the dial is on full compression.
Do you have Poploc? Did notice with Poploc fitted on one of mine that if when Poploc is engaged it didn't pull the dial sufficiently round it would obviously not get full lockout.
No poploc fitted
I'm thinking you're lacking oil in the damper.
AFIK it's 180ml +/-5ml is the normal amount, you could always take them apart if you're confindent on your spannering abilites.
Google Revelation users manual for the year and you'll get the answers
thanks steve ..you are probably right . I bought it 2nd hand and although visually A1 it had loads of stiction which I solved with an oil and seal change but I guess the rest of it needs attention
stupid question but you have tried adjusting the floodgate setting?
Retro....yes but I believe that is unrelated as the floodgate only concerns when the lockout blows off (ooh errr)!!
Kaiser,
You're talking less than 30 minutes for a damper/compression unit oil change.
BTW check out motorbike shops for fork oil, it's way cheaper than MTB stuff, quality gear if £8 for a litre from the right sources 🙂
lol can't beat a good fart joke 😉
Ah right, just re-read your original post, you're right the floodgate allows the main circuit to blow-off 😉 and even when this is fully closed a small amount of movement is normal.
I have here 09 Revelations and a pair of Pikes. Both can move roughly an inch when the floodgate+LSC (blue dial) is closed.
