0.2mm - Will it mat...
[Closed] 0.2mm - Will it matter
[#3798236]
Ordered a Thompson seatpost
Got a 27.0mm by accident
Need a 27.2mm
Send it back or chance it? Will it even matter?
Posted : 22/03/2012 11:50 am
Send it back.
Posted : 22/03/2012 11:51 am
Send it back.
send it back.
thomson have a reputation for being 'a bit' under in any event.
Posted : 22/03/2012 11:53 am
If your lucky then it'll be ok. But probably going to create problems. I had a similar issue with an old bike. Had to plump for the right size in the end as it was slipping all the time. Ridable but could never get the right clamp pressure.
It's CRC so it's a bit of a ball ache and they don't have the 27.2 in stock for a week or two
Posted : 22/03/2012 11:56 am
just araldite it in and you'll be fine.
Posted : 22/03/2012 11:58 am
Didn't you get a collect+ sticker? Should be free to return. I'd swap it.
Posted : 22/03/2012 11:59 am
Probably will not clamp very well and might put extra stress on your seat tube. No point cracking a frame just because of a bit of laziness.
Yep that 0.2 matters. Sorry
Posted : 22/03/2012 12:23 pm
send it back, or risk slipping posts and cracking your frame.
Posted : 22/03/2012 12:28 pm
Seat tube will tend to "gather" under the clamp and then crack.
Posted : 22/03/2012 12:31 pm
I can't believe that no one has yet given the correct STW answer which is to keep it and but a new frame that it will fit. As well of course getting the correct post for the existing frame.
Posted : 22/03/2012 12:38 pm
send it back.
I have to disagree - I work in a bike shop and have 3 thomson posts, one in a less common size. They measure up fine and I've not heard of this before.
Posted : 22/03/2012 12:45 pm
Send it back there's not a hope in hell it will stay put
If you use Collect+ the process is positively glacial but it will get there (eventually)
bike-discount.de have them in stock http://www.bike-discount.de/shop/k1171/a1916/elite-sattelstuetze-272-mm-330-mm.html?lg=en £58.40 + p&p
Posted : 22/03/2012 12:53 pm
I have. We had a couple of customers who had perpetually slipping posts, and they were very slightly smaller than other seatposts of the same claimed size in both instances. Ditto King Headsets.
Posted : 22/03/2012 1:07 pm
