your homemade tools...
[Closed] your homemade tools and skills?
 taka
[#778617]
[center]what have you got/made??
:roll:[/center]
Posted : 12/08/2009 11:37 am
Made all sorts - here's my titanium headset cup remover:
Posted : 12/08/2009 11:46 am
as aracer made a few. (no photos not THAT impressed with them but they work)
headset press
hope M4 bleed tool (holds pot and tube on side of frame so you can pump lever and close nipple with either hand)
hope m4 piston tool (to help clean the pistons and keep pistons open fully during a bleed)
Posted : 12/08/2009 12:07 pm
Made a spoke wrench from an old srewdriver, brake claiper wedge and hook and rope system to get the rear swingarm at the right level to get the pivot bolt/hole lined up (repeated bushing replacements on my old FSR).
Posted : 12/08/2009 12:19 pm
OOH fozzy, details please. Sounds like what I've been trying, and failing, to make.
Posted : 12/08/2009 12:21 pm
The only other photo I've got is of my home-made compressor - in both cases just to post on here for information purposes, as I thought people would be interested to see what they looked like!
Have also made the usual headset press, a Hope splined mount disc lockring tool, a puller for removing a stuck DT freehub and a Ultratorque installation tool ("made" is pushing it a bit for the latter - involved an 8mm allen key and a hacksaw!)
Posted : 12/08/2009 12:29 pm
I made a headset installation tool with 2 blocks of woods & a length of all-thread..
It's worked ok for the last 4 headsets but the wood is starting to split a bit now.
Posted : 12/08/2009 12:36 pm
I have a crown race setter and headset cup remover both made from an old frame (similar to OP). And better yet, I've just realized I can go out to my shed, take photos of them on my iphone, upload to flickr and post them on here in about 3 minutes...
Posted : 12/08/2009 1:05 pm
5 min and counting 😉
A
Posted : 12/08/2009 1:13 pm
OK fine, 11 minutes. But I had to set up my flickr account on my phone.
Posted : 12/08/2009 1:16 pm
[url= https://www.gravity-slaves.co.uk/?a=412 ]Ghetto wheeljig[/url]
Posted : 12/08/2009 1:21 pm
Nice ideas there. I have section of railway line about 250mm long that makes an excellent anvil. I can't claim to have made it, but it got bl**dy heavy after carrying it for about half a mile, so I put some effort into getting it. Don't use it a lot for bike stuff, but it is useful for shaping things.
BTW its definitely an offcut - before anyone goes blaming me for any train accidents.
Posted : 12/08/2009 3:26 pm
My BMX freewheel removal socket (it's a ss thing) has a the crew on end from a skewer permenantly attached through the centre allowing it to be held in place on the wheel.
No more punching the patio as it slips off the side of the wheel!
Posted : 12/08/2009 3:29 pm
Heaset press (big threaded bolt, nuts and wshers), wheeljig (Roger Musson), cassette removal whip (flat metal plate, hacksaw and BMX chain)
Posted : 12/08/2009 3:36 pm
Shoeing horses...making bells...? I can only imagine the list is endless 😉
@aracer i wasn't having a go, just saying that mine weren't worthy of photos.. as they are just botch jobs, the hope tool is a block of wood,
the press are washers and a threaded bar.
i have a few nipple drivers i've made none are deemed good enough to photo though.. 🙂
@ChatsworthMusters it's a block of wood i want to refine it more so i can just drop it in and it sits in the caliper.. need some time to tidy it up first.
Posted : 12/08/2009 3:56 pm
 Hip
Here's a few of mine, the obligatory headset removal punch, a spoke tool and a 36mm spanner for the locknut on the old threaded headsets...
Also a wheel building stand with dishing tool [url= http://www.singletrackworld.com/forum/topic/diy-wheel-jig ](Pic here)[/url] as well as a studding headset press and various cone spanners, mostly made from other spanners... 😉
Posted : 16/08/2009 4:47 pm
That last one looks a bit rude..........if a little square. Whats it for?
*edit* re-read...36mm spanner. d'oh!
Posted : 16/08/2009 6:14 pm
Made a "compressor" for inflating tubeless tyres. Consists of the hose off my aldi track pump (now defunct) and a 5L garden sprayer 🙂
Enough to seat most tyres at about 35psi 🙂
Posted : 16/08/2009 6:50 pm
Headset press
Posted : 16/08/2009 6:55 pm
Chain whip, Take one old chain and screw it (with a decking screw) into the end of your work bench.
Just hold wheel horizontally and wedge it against the bench and yer belly.
Job done.
P.S dont screw into block wall as it will pull out.
Rob.
Posted : 16/08/2009 7:02 pm
Ok, it's not a tool, but I was quite pleased with my recent homemade pivot bolt for my mates Scott:
Bit of garden cane courtesy of Was****er YHA, whittled down to the right diameter, screwed in nice and tight, and then cut off to length.
It got us back over Hardknott Pass to Bike Treks at Ambleside anyway.
(when he actually lost the bolt, we had to make do with an allen key tied through the hole - not quite so nice, but that got us back to the yha)
Posted : 16/08/2009 7:51 pm
