XC Racing - Ditchin...
[Closed] XC Racing - Ditching the Camelbak
[#1623701]
For xc races of around 2 hours I’m thinking that ditching the camelback and using a bottle will cut down on bulk/weight. Is this a good idea on fairly rough courses due to the potential for the bottle bouncing out?
It’ll be difficult to carry the pump, so I’m thinking of getting a CO2 inflator which I’ve never been arsed using before. Is this worth doing and if so, is something like this the right sort of thing?
[url] http://www.xcracer.com/shop/viewproduct.php?productid=58 ][/url]
cheers in advance for any advice
PL
Posted : 19/05/2010 2:59 pm
http://www.bbc.co.uk/programmes/b006th1n
How much water should we drink?
Posted : 19/05/2010 3:00 pm
The pump gets strapped next to your bottle cage, or goes in your jersey pocket. Your jersey does have pockets, right? 😉
Posted : 19/05/2010 3:03 pm
As BD implies, to perfect the sans camelback set up you need to be wearing a proper jersey with rear pockets, plus bottle cages with good grip.
You really don't need a camelback.
Posted : 19/05/2010 3:07 pm
Yes. Pump in your jersey pocket (sticking out, never lost mine) or attached to the frame/seatpost.
Depends - if you're serious, probably yes as they're much quicker
Link doesn't work for me.
Posted : 19/05/2010 3:11 pm
For racing just take the Co2 you're going to lose shed loads of places anyway.
A stout alloy normal cage is best. I've used carbon but they break in falls and the side entry ones stretch.
Posted : 19/05/2010 3:15 pm
My pump is always carried on a frame clip next to the bottle. tube and multitool in seat pouch. food in pockets. For racing or riding. Only once have I had a bottle jump out in decades of riding
Posted : 19/05/2010 3:20 pm
Yes it is basically just a velcro strap but....its betterer
Posted : 19/05/2010 3:28 pm
 will
i hope your not thinking about wearing baggies!
Posted : 19/05/2010 3:54 pm
Can't get those over here can you?
Posted : 19/05/2010 3:59 pm
Rors - good idea - I like that!
I wouldn't wear a Camelbak on a race. On the one (short) race I did, I just hoped I didn't get a flat - took water in a bottle and nowt else. If you get a flat, unless you are super speedy at changing tyres, I can't see it meaning anything but a hell of a dent to your time?
Posted : 19/05/2010 4:00 pm
Awesome strap proved to be awesome: http://teamdicky.blogspot.com/2010/02/awesome-strap-vs-mud-man.html
Posted : 19/05/2010 4:03 pm
oldgit-just order from http://www.backcountryresearch.com/ and use paypal-mine came in 5 days!!
Had a really good deal on a bundle of 3-'whammer deal' for $25.I got some braces aswell.Highly recommended (even tho it is yank).
Posted : 19/05/2010 4:05 pm
Have you tried it with road tubes?
Posted : 19/05/2010 4:07 pm
Anything sub 3hrs, you don't need a CamelBak.
Pump mounts onto frame or in back pocket. Tube/gas can/multitool in a small under-saddle pack. One or two bottles on the frame (or one bottle plus helper). If you're on your own, you can stash one at the start/finish and swap, it's the work of a few seconds to grab it and ditch the old one.
Make sure you're well fed and hydrated beforehand and have a bottle of water/recovery drink handy for afterwards.
Posted : 19/05/2010 4:08 pm
what about the integrated jersey and camelback bladder?
Posted : 19/05/2010 4:09 pm
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=21993 ]Velcro strap on CRC[/url] for £1.99, might do the job. I bought one to secure the battery of my DX bastid and works fine. Should be ok to wrap a tube and levers round and be tight enough. At 1.99 it's not that expensive and probably worth a try.
[edit] This velcro strap is 27mm wide [edit]
Posted : 19/05/2010 4:18 pm
Isn't the awesome strap one of these:
5.99 a pack from Maplin
[url= http://maplin.co.uk/Module.aspx?ModuleNo=227645 ]http://maplin.co.uk/Module.aspx?ModuleNo=227645[/url]
Posted : 19/05/2010 4:20 pm
The strap that came with my L&Ms is great. No narrow straps don't work or last on the seat post, they pinch the middle then the bits rotate. You need something wide.
Edit or fairly solid! I assume that strap is the latter.
Posted : 19/05/2010 4:23 pm
Its the non fluffy velcro that still works when its muddy.Its also got a rubber non slip bit where it goes round the seatpost and a 'buckle' type thing so you can cinch it down hard.Christ I sound like a salesman!!
oldgit-cx tube/mini pump/levers is fine on mine (just fold the tube over more)
www.youtube.com/watch?v=bFE1i7MPQDo&feature=player_embedded
Bear with the yankspeak-"double thumbs down"!!"if youre gonna take a digger...golden"
And its treated with TECHTRON spray and uses no.92 polyester..."in like flynn". 😀
Posted : 19/05/2010 4:29 pm
where can i get hold of a awsome strap in the uk ?
Posted : 19/05/2010 5:13 pm
Just run robust tubless with sealant. No need for all that CO2 stuff. I've been doing this for a couple of years now.
Have a good slug of water before you start, and away you go.
I've never had a bottle bounce out of the cage yet.
If it's really hot get wife/daughter/boyfirend/mother/son/auntie/dog/friend to hand a bottle up.
I hate Camelbaks. Tried one once. Hated it.
SB
Posted : 19/05/2010 5:39 pm
PlumzRichard-'just order from http://www.backcountryresearch.com/ and use paypal-mine came in 5 days!!'
Posted : 19/05/2010 5:58 pm
Still worth carrying CO2 for if you flat though, tubeless is hardly puncture proof, although carrying CO2 can mean you just reinflate and ride off, having stopped for all of 20 seconds.
Bottles all the way, there's always someone to hand fresh ones up!
Posted : 19/05/2010 7:58 pm
I got my velcro straps from a guy in America who was featured in Dirtrag. They're really good. Loads of colours to choose from. They have very strong velcro, sturdy D ring and a rubberized secton so that it doesn't rub on the seatpost. Not a single mark on my carbon seatposts. I'll see if I can find a link.
Posted : 19/05/2010 8:10 pm
*runs off to buy a bottle cage before sunday*
Posted : 19/05/2010 8:31 pm
Found it. [url] http://byekyle.blogspot.com/ [/url]
Posted : 19/05/2010 8:34 pm
I used a Camelbak in a local XC race.Worked for me. A sweaty back,is a small price to pay for easy sipping.
Posted : 19/05/2010 8:42 pm
Ive never got on with camelbacks for racing ....tried several - only using them for non lapped events now as feed stations tend to be chaos ,,,...
Anything lapped i just make up a few bottles and stash em or get the passed up when i need em .
I tape the pump to frame or stem or seat pin as the pump brackets never seem to last with me . Tube gets taped under the seat with electricians tape
Co2 pump and multi tool goes in back pocket as does a gel or 2
Almost always use a camelback without bladder for audaxing though .....ie a bag !
Posted : 19/05/2010 8:45 pm
TBH when not racing why carry anything? if my mate wants to carry a Camelbak I might as well make it worth his while 😀
Posted : 20/05/2010 9:22 am
Best Velcro ships with cable management arms for servers. Go and tap up your IT department. Sticks like poo to fur.
Posted : 20/05/2010 9:31 am
And anything longer, you want to avoid having the weight on your back 🙂
Posted : 20/05/2010 9:33 am
