X Fusion Slant Lowe...
[Closed] X Fusion Slant Lower service
[#5614859]
Has anyone had a go at doing a lower service on these forks themselves, the how to video says to use a RL2 damper removal tool, is this needed, ff so where do you get one from?
Posted : 18/10/2013 3:03 pm
 Dan
there is also a DL2 service pdf that shows locking out the damper allows the nut to be put back on without the tool, it would be good if other folks chip-in if they have done this.
Posted : 18/10/2013 4:38 pm
Done the lower service no special tools needed, did the travel adjust to which just needed some circlip pliers
Posted : 18/10/2013 4:49 pm
Same here no special tools adjusting travel on an RL2. I slackened off the foot nut about 5mm and tapped the socket on the foot nut to release it. I didn't lockout the damper but I will next time thanks for that tip. The damper rod lined up with the lower for me so I just put the foot nut back on and tightened up. It was all quite painless.
On a side note does any one know if the SKF seals for a fox 34 will fit the slant?
Posted : 18/10/2013 5:08 pm
Cool cheers for feedback chaps looks a nice simple procedure just like my old lyriks
Posted : 18/10/2013 7:36 pm
 Dan
so I can see why the tool is useful; when replacing the lowers not a lot of thread pops through (the tool grabs a lot more of it) and there is a risk of stripping the thread on the damping rod.
Posted : 18/10/2013 9:31 pm
