Looking for one for sons new bike.
Needs to be cheap & 104BCD.
Thorn do one but it's 110BCD I think.
TA do a Carmina and maybe a Vega in 160mm, which can be mated to a 4-bolt spider (double or triple spider, square taper). The missus has the 160mm Carmina 4-bolt and it's nice but not what you'd call cheap.
Have a search on BMX cranks, they should come in short and cheap and 4-bolt.
ah... Thorn do a 4-bolt too:
http://www.sjscycles.co.uk/thorn-104-64-pcd-triple-crankset-mk2-black-prod31813/
Im sure my Zee are 165mm.
Buy cheap set of 175's. Cut the end off,drill and tap new threads (may need to be a bit shorter than 160 though).
[url= http://www.spacycles.co.uk/products.php?plid=m2b0s109p2000 ]These[/url] come in 160, and are quite cheap unfortunately they are 110/74 BCD 5 arm...
Does it absolutely have to be 104 BCD?
I have some 104 chainrings and a Hope bash guard I was hoping to reuse.
Zee nicer than my bike, and that isn't going to happen.
Spa Cycles
