Basically need a tyre for my Genesis cdf that is not draggy on road but when I cycle to trail centre will work there also with good grip.
What would you recommend?
40c WTB Nano's are probably the best all rounders.
Despite their tread and size they roll really quite good on the road.
Off road only becomes a problem when you hit deeper mud or slick grass (since they aren't knobbly).
EDIT: Provided you have clearance for a 40c tyre?
Max I can go is 33 with mudguards or 35 without
Despite being performance line, i found Schwalbe rapid robs pretty good, don't break the bank either. Only thing i didnt like is they wore out really quicky.
I like conti-crossspeed 35s on mine. Very good all-rounder.
Have been looking at Clement pdx's anyone using them.
[i]Have been looking at Clement pdx's anyone using them.[/i]
I have them on my training bike. They are a really good intermediate condition tyre. They are pretty good on the road but they do wear quickly.
I had the pdx they are an all out race tyre for mud. The mxp is more of an all rounder but still a race tyre and is slow on the road and will wear quickly.
schwalbe smart sam are pretty good if you can't fit nanos in
Clement xplor are good in either flavour (mso or the other one ush?) depending how much off road grip you want
put a file tread on the rear, something a bit more intermediate on front?
My problem is I need to cycle 12 miles on the road before I reach my nearest trails and the the same back on the road. So probably moon on a stick
I had planned to swop out the cross-speeds for light back road touring but they are actually so decent on road I haven't bothered. Done a few weekends away with them, loaded up with panniers etc. They are no slower than a pair of 32 conti touring slicks I have. Off road they are good in all but proper gloop
http://clementcycling.com/xplor-mso
I've ridden plenty of road miles on 32 mso. Currently running 35 ush
Left them on my cx all winter last year for everything- winter road rides, cx rides and commuting. Less off road grip but ok except mud, plenty fast on road
^^^ I bought a set of those ush ones for when my cross-speeds wear out. They get good reviews but I haven't tried them yet. Hope they are as good as the Conti's ...
Sammy Slicks have done it for me. Cheap as well.
@ceepers does the mso offer good side grip in the corners on gravel/hardback
In my experience yes! I think their weakness is mud, on hard packed dirt/ sandy trail/ gravel they're good!
I've done a (slow) winter exmoor 50 mile road ride on them in the past as well! I swapped to ush because in reality the bike gets more road miles and they have a slightly more road (country lane) bias and I'm too lazy to swap tyres around regularly. I'll probably put the mso back on when it's summer again and it's my proper road bike doing the Tarmac miles
Just the fact you are on a drop bar rigid bike instead of a mountain bike is the biggest limiting factor on your cornering speed I think!
I was wondering the same as OP and saw these, heavy but look do it all, anyone used them?[url= http://www.towsure.com/schwalbe-tyrago-k-guard-tyre-700-x-35c-reflective-sidewall ]scwalbe tyrago[/url]
Ceepers that's a factor I hadn't taken into account. I'll be going a damp site slower in the corners that I would on my Horsethief
Had these in 38mm too. Better cushioning and off road grip but definitely more draggy on road
http://www.chainreactioncycles.com/schwalbe-cx-comp-cyclocross-bike-tyre/rp-prod24615
There's no way they will fit
Think I'll give the Clements a go
Specialized Roubaix 32's. No problems here.
[URL= http://i1097.photobucket.com/albums/g341/kiwijohn42/DSCF6403_zpsyfcg58ae.jp g" target="_blank">
http://i1097.photobucket.com/albums/g341/kiwijohn42/DSCF6403_zpsyfcg58ae.jp g"/> [/IMG][/URL]
Clement Xplor USH are my favorite. Fast on road, plenty of grip on hardpack considering what they are. Great on gravel roads. Puncture free and wearing well with about 1500Km done.
Quite like Conti Speed for grip but they wear out fast and not that puncture resistant. Mate swears by some other things at 40c. Paid a fortune for them from the states (will try and remember what they are )with similar pattern to the Contis. Already looking shabby on the rear at 300km.
bit heavy but no punctures for 3 years! 32mm swalbe marathons (green guard) for me - not so good on mud but very predictable on loose gravel roads and great on dusty single track, roll well on tarmac
[url] http://www.bicyclerollingresistance.com/tour-reviews/schwalbe-marathon-2015 [/url]
Content with my Small Block 8s on the road, decent off road.
If you actually mean Trail Centre then you can probaly go quite road biased. Its actual mud that needs lots of tread and that isn't really a feature of most trail centres
Ampthill, the the trails are pretty much gravel/hardback not much mud and I can avoid the real rocky sections so the clement x'plor use would work well.
I use Vittoria XN Pro's all year round in similar conditions.
I've used cx comps a lot . Good ,cheap and fairly hard wearing. Some punctures.
Now on land cruisers , which so far appear to be bombproof and heavy.
I'm lazy so I'll get used to the weight if it means I'm not fixing a puncture at 5am.
