What are the best 1...
[Closed] What are the best 160mm Forks??
[#3294023]
So yeah... fire away!!
Posted : 29/10/2011 6:51 pm
Coil U turn Lyriks.
Posted : 29/10/2011 7:25 pm
Coil U turn Lyriks. +1
There just soooo good.
Posted : 29/10/2011 7:29 pm
BOS Deville
Posted : 29/10/2011 7:32 pm
I've 2 pairs of coil u-turns. great on big hits but not so good on fast chatery stuff. the damping, even when set to its fastest, is a bit heavy for that stuff. Fox 36 are usually buttery smooth on that stuff....but cost considerably more.
BTW I managed to pick up both my sets of lyriks, new, at cosiderably under rrp. £530 ish for one set and £388 for the second set!
Posted : 29/10/2011 7:50 pm
Don't claim to know which are the best but I love my BOS Devilles.
Posted : 29/10/2011 7:52 pm
If I thought I could get away with fixed length I'd be all over a set of Devilles. As it is, I'll stick to my Lyriks. Shame they can't roll the mission control damper out to more forks, it's class- and so easy to use.
That said, it should go without saying that 2-step air is the devil's own spring.
Posted : 29/10/2011 8:28 pm
Neilnevill, the 'dh' damped lyriks seem better than the standard versions for high speed chatter. I'd still chose a standard lyrik over a van 36 anyway, performance is so close but damping adjustment is a bit more useable, price is lower and most importantly they wear significantly better in uk conditions.
Posted : 29/10/2011 8:38 pm
Ah yeah, I always forget that- mine have the lockout removed, and it does make a noticable difference, not quite the same as the MCDH but very close. Made about the same difference to small-bump response as going from air to coil did in mine, which really surprised me. (then again the Lyrik air springs are very good when they're not exploding)
Posted : 29/10/2011 8:40 pm
yeah I think the lyriks are better value....i went back for a second pair a year after getting the first....but the £388 price tag helped!
I've heard removing the launch control/lock out helps. Supposed to be easy and reversible isn't it? I kindo of like the lock out for climbing though. I was thinking of just putting some thinner oil in, say some 5wt. Anyone tried it?
Posted : 29/10/2011 8:45 pm
neilnevill - Yes and Yes!
Floodgate mod is simple, and 5wt makes a massive difference. You will need to apply more rebound though as its the same fluid for both rebound and compression.
I have also done the "Boxxer" mod, i.e. swapped out the inner oil seals for foam rings. TFT reccomended it and will supply the 35mm rings required, and I must say it makes a big difference. But be sure up those service intervals!
Posted : 29/10/2011 8:59 pm
Fox 36 van rc with the new SKF super slick seals, way way better than my old lyrics.
Posted : 29/10/2011 9:07 pm
Coil U turn Lyriks.
+ Mission control DH cartridge, turns an already great fork into a mini set of Boxxers!
Posted : 29/10/2011 9:11 pm
twohats.
Wouldn,t mind sticking a DH cartridge in mine.
How much are they bud and from where..TFT-loco??
Posted : 29/10/2011 9:15 pm
 grum
Not tried Lyriks but my 36 Van RCs are ace. No way I'd be buying them at current prices though.
Posted : 29/10/2011 9:20 pm
180 vans lowered to 160.
Not sure on retail cost as I got mine at trade, probably about £80 ish, I'm sure Loco, TF or any Rock Shox dealer could sort you out.
Just fitted the the dual flow rebound cartridge as well to complement MCDH cartridge...
Posted : 29/10/2011 9:21 pm
Bloody ell.
Talk about a moded to death...lol.
Posted : 29/10/2011 9:33 pm
Lyrik coils running DH damper, awesome.
Not totally bomproof but very basic to service and repair yourself. An oil change in lowers every 6 months or so and they are champion.
Konastoner, thanks 🙂 I shall go forth and fettle sometime soon
Posted : 29/10/2011 9:44 pm
Love my Van36 RC2s, but not sure i'd be up for paying the current asking price. BOS prices look more reasonable every year.
Posted : 29/10/2011 10:09 pm
Marz 55RC3Ti. 3yr warranty with no service stipulation unlike Fox every 5 minutes.
Big fan of solo air lyriks with the lockout removed but picked up some 2010 marz half price from wiggle (despite being identical to 2011 and poss 2012 due to 3 yr product cycle) and hoping they gel with my coil rear.
Best depends on what you pay, some serious bargain lyriks mentioned above, and marz @ 450 look far more attractive than at retail of 900...
Posted : 29/10/2011 10:19 pm
My 36 vans and talas have significantly outlasted my coil lyriks with similar servicing and use.
Would like a go on some BOS forks.
Posted : 29/10/2011 10:22 pm
I got put of 'zocchi after owning a set of AMSLs....back to WW for a damper fault, back again for a ETA cartridge failure...failed again and...give up. If 'zocchi are reliable again the I'm sure they are great though.
Posted : 29/10/2011 10:32 pm
+1 on 'zocchi 55 RC3
Posted : 30/10/2011 8:19 am
