Just taken delivery of a Bizango frame and now need a headset. I've measured inside from the top and bottom to the ridge that's inside the headset and it's 10mm. You can just see the internal ridge here -
I thought I'd found which headset I can use from Nukeproof (T2 and B5 here -
), but the lower cup inserts by 14.8mm so it'll hit the internal ridge before being seated correctly. So, what are you people running? I want to go for a tapered steerer, so would need an internal top cup and an external 44mm bottom cup. But who does a bottom cup that only gets inserted by 10mm or less.
Thanks!
would some sort of spacer work?
a quick search actually reveals this is a bad idea, please ignore!
chop off the excess 4.8mm?
http://blog.sidewayscycles.co.uk/2011/03/25/1-5-steerer-integrated-headset/
(I know it's about 1.5 steerer but the bottom cup is the same..)
Hmmm, yes that could be done. I have a friend with a lathe. I don't really want to spend £60 on a Hope when the frame was only £100! The Nukeproof option would be just over £30, but still preferable to try and find a bottom external cup that has an insertion depth less than 10mm.
Hang on wouldn't a Hope H fit... ahhh I see you conundrum...
This [url= http://singletrackworld.com/forum/topic/44mm-semi-int-headtube-15-tapered-forks-headset-options ]Thread[/url] might be of use?
Got a Hope mix and match in mine, works fine.
Thanks. If all else fails then a Hope it may need to be.
I've emailed uber bike asking what their insertion depth is. Stop s****ing!
News from Uberbike is that their headset goes inserts 7mm, so we have a winner!
This is what I did.
Great frames btw - no bling value but sorted geo and very cheap!
Hope in the bottom of my Voodoo Bokor to fit a taper.
Oh and a Hope's not £60. You just need the bottom cup, under £30 IIRC.
I need a full headset though. Frame was sold with no headset, so I need both bottom and top cups.
I know. I did think about it, but mintyjim was offering wheels too. I'm surprised yours haven't gone quicker.
This one?
[url= http://www.uberbikecomponents.com/view-product/Uberbike-15-Headtube-Tapered-Fork-Headset-Stainless-Steel-Bearings-Gold ]headset[/url]
Yes, that's the one I've just bought, but in black.
ta
Given up trying to sell mine - going to build it back up. Fun ride.
What size frame, condition & price Clink?
I had two 18" frames for sale, one BNIB one used. Gave up trying to sell, so probably keeping one for myself (ss) and build others with gears for my wife.
