Toddler cut head - ...
[Closed] Toddler cut head - hospital?
[#4751387]
Night three for Toddler North in her new bed and she' s fallen out and hit her head causing a small gash in the scalp. it's about half a centimetre long.
Worth going to A&E for it to be stitched or is that too small a cut?
Posted : 14/01/2013 11:13 pm
 Pook
clean and dress, and keep an eye on it.
Posted : 14/01/2013 11:15 pm
Close it with a steri-strip?
 Kip
NHS Direct - 0845 4647
They'll be able to answer any queries professionally based on information you give them over the phone.
Posted : 14/01/2013 11:16 pm
Minor Injuries Unit or Walk in Centre if you have one to checked for other symptoms and have it cleaned. It can scar easily when they're young, be prepared to be asked a few probing questions though.
Posted : 14/01/2013 11:17 pm
NHS Direct tend to refer direct to A&E for all small people injuries.
TTFU.
Posted : 14/01/2013 11:18 pm
Sounds small, but I can't see it. Have you tried thin bit of non-adherent dressing across but with tape pulling it closed a bit. Toddlers make you update your first aid kit fairly regularly.
Ask someone responsible will you? Posting the question on here is not a good indicator.
 Kip
Too Tall - Kind of the point I was trying to make as well 😉
Posted : 14/01/2013 11:20 pm
[url= http://www.nhs.uk/Conditions/Head-injury-minor/Pages/Symptoms.aspx ]Minor Head Injury[/url]
Posted : 14/01/2013 11:21 pm
On the phone to a quack at NHS Direct right now.
Am off to check first aid kit. Either that or gaffer tape.
Posted : 14/01/2013 11:22 pm
 Kip
Posted : 14/01/2013 11:23 pm
Chill out TooTall FFS. Child is perfectly happy, cut is small, medic advising.
Kip - I'd think subtle would be lost on the OP given the question posted!
Posted : 14/01/2013 11:24 pm
superglue is your friend 🙂
Unless it's big enough for stitches, the hospital would only gaffer-tape it up anyway...
Posted : 14/01/2013 11:25 pm
He's trying to divert attention away from the baseball bat hidden in the shed after too many hours of sleep deprivation.
Seriously though best get it checked.
You posted a bone question about the wellbeing of an injured child on a mountain biking forum. I took the proverbial because it is a bit bone.
Chill out and concentrate on your bairn, not internet numpties poking fun at your bone post. On a cycling forum. About an injured child.
Getting high won't make the problem go away.
Posted : 14/01/2013 11:26 pm
Off to a&e....
Posted : 14/01/2013 11:28 pm
YAYYYYY 😀
Posted : 14/01/2013 11:29 pm
 Kip
TT - go easy 'ey. The OP [u]is[/u] talking to a professional, as suggested, and he's getting it sorted.
Sometimes we all forget about the most obvious and easiest answer especially if the child in question doesn't seem phased. I guess he was just looking for a bit more advice to go on top of his gut feeling about the child he can see and he knows best.
Second opinions never hurt.
Hope Toddler North is Ok, and well done on the big bed. Still waiting for Small Kip's first proper launch out of hers!
Posted : 14/01/2013 11:33 pm
I remember my three year olds first night in his big boys bed- THUMP- I was up the stairs like a rat up a drainpipe.. Not that I was listening or anything..
Anyways- superglue will prob be the answer at the hospital I'm guessing- depending on how deep it is!
Posted : 14/01/2013 11:50 pm
We used one of those 'fence' devices that slides under the mattress and sticks up to stop 'em falling out while they get used to a proper bed. Worked a treat.
Posted : 14/01/2013 11:54 pm
ok smartarse, you've glued her to the bed so she can't fall out, how are you going to get her up in the morning? hmmmm? didn't think about that one did we!
Posted : 15/01/2013 12:15 am
Blue superglue. Son1 did this after cutting his head on a plant pot falling off his first wooden bike. 1cm gash that wouldn't close. Bled like a stuck pig. Lie on front. Prevent thrashing (a lot of thrashing!). Nurse closes wound with superglue. Preferable to stitches (where no anesthetic is used).
Don't F about on STW, get on NHS Direct!
Posted : 15/01/2013 12:16 am
NHS [i]re[/i]direct... Pfft.
In my experience, usually get more sense (and sense of humour) from NHSTW. Bleeding pointless entity. (IMHO, of course)
Posted : 15/01/2013 12:19 am
NHS Direct were always likely to say hospital. But half a cm? That is seriously tiny.
Posted : 15/01/2013 12:24 am
 poly
I once watched a doctor tie hair together across a much larger scalp wound than that. (We were about 3 hours from nearest A&E). Seemed to do a very effective job. By the time we got to civilisation the decision was not to even bother disturbing it to stitch it. Of course improvised repairs may be less appropriate on children, or where help is closer to hand.
Posted : 15/01/2013 12:30 am
since we're talking glue, and Drac and possibly other people who wear white coats are in....
Why isnt the home application of superglue encouraged? I dont think it's in first aid courses? Its hardly any more complicated than applying steris. I self administer for cuts and eczema, but havent yet needed to glue Stoner Jr [s]to the floor[/s] together yet, but I wouldnt baulk at it if the opportunity came up.
Posted : 15/01/2013 12:32 am
Top Macgyvering! Im remembering that one!
Posted : 15/01/2013 12:33 am
One of my girls did the same but head butted the top of a radiator. Quite a lot of blood and an open wound about 1cm long.
Quick trip to a&e (bit too quick as it cost me points for popping through a light just turning red) some superglue and back home.
Small scar there still 4 years on.
Posted : 15/01/2013 12:35 am
The hair technique is actual procedure that's a very effective.
Stoner it not the same kind of glue for start and there's a bit more to it then sticky a wound closed, which is why first aiders aren't taught it.
Posted : 15/01/2013 12:36 am
Cyanoacrylate + Aquamarine Blue? 😉
Go on then, show us yer skillz, what makes it more complicated than sticking it together?
Posted : 15/01/2013 12:37 am
I think the general aproach with scalp wounds on kids is "if you can see any clean head at all under the gushing blood, it's a minor injury and safe to leave alone"
I have no real idea what a stuck pig bleeds like, but it can't be nearly as heavily as a toddler with a grazed scalp
Note to TT - 😉
Posted : 15/01/2013 12:38 am
Cause, length, depth, width, still bleeding, location, age of patient, previous medical history will that do for now?
Posted : 15/01/2013 12:41 am
Medical superglue is a slightly different compound, upposedly less irritant I think. No idea whether this can be supported with evidence
Scaredy you're right it's a different formula but don't worry it would seem others not trained in it no better than those who are.
Posted : 15/01/2013 12:43 am
I can spell better 😛
Posted : 15/01/2013 12:44 am
stoner - medical grade super glue (derma bond) is basically a purified 2-octyl cycanoacrylate it doesn't contain the additional trace compounds that can be skin sensitisers.
Unlike commercial stuff which is ethyl cycanoacrlyate plus additional solvents . This is also why commercial stuff actually sticks better!
superglue is bloody ace for my own cuts, mind
will I, err, you know, .... 🙁
Posted : 15/01/2013 12:46 am
I won't argue with that Stoner. 😀
oh and loctite permabond stings like a b*****d whereas dermabond feels a damn sight better. I used to use it lots when climbing...re-glue mangled hand,dip in chalk bag, back to it.
Posted : 15/01/2013 12:47 am
