Any stock? Enough interest for a group re-order?
I'm quite keen on a 35T in black.
Keenness here too, but prob of the 34 tooth variety...
Can't say I'm not curious, would depend on price
Is interested, just been looking at the Goldtech ones.
Unsure what size mind, currently on a 32t..
come [i]on[/i] Al, I've a sweepstake to win ...
Maybe a 34 for me, got a 33 already but need another for a different project but will depend on price as not desperate.
yeah - currently on 32
Goldtech ones.
they are the tazzy wibbly wobbly rings. They have a good stock at the moment, uno compatible ones as well. all sizes from 33-36. Listen to you unkle tazzy this is the important bit. GO up at least 2T on your normal SS ratio, it's the magic number.
you can contact Kev direct or if enough folks are interested let me know and I'll go and do some bartering for a group deal.
OK I'm in for a 34 then, should I go to 35? (eeeek!) ps as long as they fit on SLX
mattjg on what bike? 34 or 35:19 is wicked on a 29er
scaredy- who's money is on me waiting till they're all on the classifieds? 😉
Ballpark price? Would be after 34 Uno
lolz will you [u]Actually[/u] try one then Al? 😛
@tazzy 29er currently running 32:18
Well OK, if there's any sort of group thing going on sign me up for a 34, why not?
Ok it's been a long week and I'm tired so stupid question just to be sure......for front clearance issues I need to stay at 32 front and therefore I drop two teeth on the back?
34 will be sweet, then mate
(no issue going to 19 on the back if it helps - the 18 is getting worn anyway)
Al - I'm in awe! When did you actually get yourself a title other than just a member?
33 is the smallest wonky ring they do.
tazzymtb - Member
lolz will you Actually try one then Al?
Maybe, for reasonable money. I'm curious, have I ever said anything against them?
Rickos, what can I say, I earned it 😎
I need a new 33 UNO ring .......so is there going to be a group buy ???
with pounds/cash/money donation to the powers that be 😉I earned it
I paid for it AND earned it 😎
@Gotama this is for your Swift? (If it won't fit on yours I guess it won't fit mine). What cranks do you have?
I'd be interested in a 34 🙂
they fit on a swift no problems
had a 33T, sold it
I gUeSs ThIs ThReAdS's NoT fOr YoU tHeN.
If the price isn't terrifying I'll have a 33T 104BCD one please.
Any idea on the price?
Will the one they describe as Shimano Centrelock fit a Middleburn crank?
Thanks
Mattjg - no for the yelli. It's ridiculously close to the chainstay with a 32 mounted on the inside of the spider. I could shift it to the outside and the move the sprocket at the back across but, rightly or wrongly, I have it in my head that the further out you run the rear the more pressure it puts on the pawl springs.. Might try a 34 and if it doesn't fit I'll stick it on the swift as I am oval curious.
Mine fit a swift with deore HTII cranks no probs
I don't think anyone is contesting whether they fit a swift.
How would this work on a sniggle speed full sus? Would counteract any bob or make it doubly bad?
What are they?! 😕
elliptical ring for singlespeeds njee20, means you can run a bigger gear and get over grunty stall points on steep climbs. May work on 1 x 10 etc but never tried it with that.
How come they didn't work back in the day but they do now ? Snakes piss 😉
Is there one for the old XTR spline type cranks? The 33 Jericho Suffering on mine has very pointy teeth and is beginning to scare me... I wee ride on Taz's ring is temping me.
firestarter - Member
Different orientation - and jury out on "works now".
yep wiggo used elliptical rings cos they are gash 😀
and ned overned
and the niner ergon mtb folks
and the specialised factory xc team
and the garnim team
and carlos sastre
and some single speed giffers 😀
Gotama - MemberI don't think anyone is contesting whether they fit a swift.
whatever you say chap 😆
and jury out on "works now".yep wiggo used elliptical rings cos they are gash
He said jury's out, not they're gash. If they definitely worked then every single rider in the peloton would use them, plus SRAM and Shimano would make them!
I'm interested to try them (elliptical rings generally). Doubt you do 88mm BCD anyway though? And I already run a 36t, so it's not looking good!
have a chat to the goldtec chaps, they can cnc all sorts of variations. They have made a dinner plate 60 odd tooth elliptical for a track bike for some record attempt thingy wotsit.
