Swapping my chainri...
[Closed] Swapping my chainring 32T to 36T on 2x9 - any issues?
[#3639061]
Planning on swapping my chainring from 32T to 36T on my 2x9 and bash set-up.
I assume this shouldn't affect shifting performance, and should need little or no adjustment to my front mech? Will also check the chainlength is still ok.
Posted : 03/02/2012 11:27 am
only issue may be that you need to lengthen the chain if you'd shortened it for the 32?
[edit] did you add the chainlength bit or did I just not bother to read the whole thing?
Posted : 03/02/2012 11:28 am
 sv
Having to drop to the small ring more often.
Posted : 03/02/2012 11:30 am
If you've got a double specific front mech you'll be fine.
I have bodged a 2x9 from a 3x9 SLX, and switched the 32 for a 36. I have the original triple front mech and the shifting is a little clunky and it was very difficult to get the mech into a position where everything worked without the chain rubbing on it in certain gears.
Posted : 03/02/2012 11:34 am
Wwaswas, no I didn't edit the chainlength bit, I just assumed i'd need to add a couple of links.
I didn't realise there were double-specific front mechs.
Posted : 03/02/2012 11:48 am
the shift from the 22 to 36 and back again will not be as smooth.
I find it best to use it as a two ranges of gears - so use the 36 on the flat and downs but at anything but the slightest hill change at the bottom to the granny ring and use the bottom 6 gears on the cassette - so I might start climbing in granny 5
this avoids having to shift halfway up the hill
Posted : 03/02/2012 11:53 am
Cheers guys, that's useful.
I assuming this SLX Double-Specific Front Mech would work:
[url] http://www.madison.co.uk/productinfo.aspx?catref=FDM667X5 [/url]
But would I also need a double-specific shifter? I currently use an XT triple shifter with my 2x9 with the limiter adjusted so it works as double.
Posted : 03/02/2012 12:34 pm
I run a 37/29 double set up with an XT front mech (triple) with the stops adjusted correctly and have no issues whatsoever.
Posted : 03/02/2012 1:15 pm
I have no problems running a normal 3 speed Deore front mech on a 24/36 set up. Like lostboy says, you've just got to set the thing up properly.
Posted : 03/02/2012 1:20 pm
You don't need a double specific shifter.
I found the double specific mech made a huge difference in avoiding dropped chains but I don't use a bash on my double.
Posted : 03/02/2012 1:22 pm
I think i'll try and stick with my standard XT Front Mech for now. I've set it up no problem as a 22-34T Double and Bash with careful limit screw adjustment, so changing to 36T should be ok.
Posted : 03/02/2012 1:28 pm
Run a 36/22 with a regular front mech - no issues.
Posted : 03/02/2012 1:31 pm
Out of curiousity whats the difference between 22/36 and 29/37?
Posted : 03/02/2012 1:40 pm
I kept the same shifter but had to change my xt mech to the double specific slx. Apparently XT triple front mechs can only cope with a maximum of 12 teeth difference in the rings where as the slx double can do 14.
Posted : 03/02/2012 2:05 pm
Really?
Posted : 03/02/2012 2:09 pm
front mech will need to slide up the seattube a bit. ime.
you need to keep the middle ring notch in line with the middle ring.
Posted : 03/02/2012 2:11 pm
I use a standard triple front mech - a seven speed one at that.
Agreed.
Posted : 03/02/2012 4:01 pm
Agreed, agreed.
Posted : 03/02/2012 4:11 pm
0.17267267267267267267267267267
HTH
Posted : 03/02/2012 4:36 pm
