Sunringle Ryde XMB ...
[Closed] Sunringle Ryde XMB Freehub removal
[#3944311]
Has anyone managed to get one of these off and replace it? Can't do warranty and yes I know they have issues but I would quite like to revive my wheel as it is good otherwise and I'm a bit of a fix/repair freak!
I have managed to get the axle out and drifted both sets of cartridge bearings out but the freehub it'self baffles me! any ideas?
Wheel is off a Cube Ltd Race 2010 which has I believe the Mk2 Ryde XMB Hub
Posted : 04/05/2012 11:36 pm
Is it not like a shimano freehub where you use Allen key. From memory that's how I have taken them apart.
Posted : 05/05/2012 7:18 am
I will have a try when I get home but I didn't think so...
Posted : 05/05/2012 8:00 am
Can you send some photo's I have a spare freehub I think at home and it has Allen key retaining bolt and a allen key for fitting the freehub.
Posted : 05/05/2012 10:38 am
Think you need a special tool.
Posted : 05/05/2012 7:05 pm
It is an allen key 12mm i think and it goe's in through the non drive side first to undo the bolt and then non drive or drive to undo the freehub.
Posted : 07/05/2012 12:05 am
This sounds like the free hub I have.
Posted : 07/05/2012 9:32 am
hello, i've got the same problem. however i've not got to removing the axle. I've used a cone spanner to help remove the drive side nut, can somebody please point me in the direction of what to do next??
many thanks.
Posted : 29/05/2012 1:06 pm
Remove axle and bearings. Put 11mm Allen key in a vice. Place the wheel disc side down onto the Allen key. Turn the wheel anti clockwise. Turn the wheel over and repeat.
Posted : 30/05/2012 9:16 pm
