STW research club, ...
[Closed] STW research club, I propose for the second subject building 7 9/11 event
[#4449143]
Is anyone interested in researching this event, with an open mind and reasonable grasp of logic?
Posted : 11/10/2012 6:46 pm
I propose this footage as the first evidence to be discussed and explained if possible.
How can this building collapse like this when doing so defies the laws of physics http://en.wikipedia.org/wiki/Path_of_least_resistance
How is it possible for a building to do this, I cannot justify this happening without a controlled demolition, however if there is a way for this to occur I would be interested in hearing about it!
Posted : 11/10/2012 7:19 pm
Icke, is that you?
Posted : 11/10/2012 7:20 pm
Pretty much guaranteed to be the same malevolent power that is currently using my [url= http://singletrackworld.com/forum/topic/compostbintrackworld-first-time-composter-help ]compost bin[/url] as a portal into our dimension..
Posted : 11/10/2012 7:22 pm
You know this is an internet forum don't you?
Posted : 11/10/2012 7:23 pm
Didn't you do this about a month ago?
Posted : 11/10/2012 7:24 pm
I am still digesting your thesis on earthquakes and ill defined solar forces
ps
Its because you dont understand the laws of physics
Is there no account of this on the internet without reference to a controlled demolition ...not even from the deceiving capitalist controllers of our thoughts feeding BS to the stupid masses.
In which case it is what you said as you are an expert on research, physics and demolition
thanks for sharing
Can you do cold fusion next?
Posted : 11/10/2012 7:25 pm
Has your carer nipped out for fags again?
Is there a name for the logical fallacy that goes "I don't understand something, so it can't be true"? You know, the same mental defect that causes Creationists?
Posted : 11/10/2012 7:29 pm
Junkyard and everyone else do you have the ability to simply stick to the subject or is it too difficult, if you did we really could investigate this and maybe even learn something.
Also if the UK and western world can get out of this way of thinking and behaving, we might be able to sort out the mess we have made of our way of life.
The only thing that is relevant to this thread is building 7 9/11, so if you can find me an example of this happening anywhere else then present it for evaluation.
Channel 4 have just crashed a plane into the desert to see what happens, maybe you could persuade them to fly the next one into a skyscraper?
Posted : 11/10/2012 7:32 pm
You had a thread on this and started a new one - remember what I
said about you criticising us for your own failings?
Yes I am sure you are willing to change and this is why you keep coming up with these threads it because you might just change your mind and you want to impartially evaluate the evidence. The OP about it defying the laws of physics let me know that
See my point above about you calling others for your failings
Yes you are sounding open to other views you really are
What about the twin towers
[s]Lights touch paper[/s]detonates hidden explosive charges and runs away
Posted : 11/10/2012 7:38 pm
I do wonder why some people waste so much on these threads. He's simply trolling, IMHO. Rather boringly, too.
Posted : 11/10/2012 7:45 pm
So we are agreeing that planes were flown into the buildings.
Would it not have been easier to just pretend terrorists planted bombs,
how did the US enlist the help of the terrorists?
Posted : 11/10/2012 7:51 pm
Yes.
Some planes flew into some buildings.
It's a closed mind with a childlike sense of logic that can't understand this.
Posted : 11/10/2012 7:57 pm
I'm going to feed him.
1) Yes it will happen.
2) You need to understand construction and physics
3) You need to take your rose tinted glasses off and stop being naive looking for something, however far fetched, to suit the answer you've already concluded
I have to say I feel quite sorry for you.
zippykona, unfortunately I am only willing at this point to stay focused on the footage provided and discuss it.
Other wise all we will end up with is a useless ego fueled bout of arguing and posturing.
The only way to research something is to fully evaluate the subject matter proposed, for now that is the footage provided and the fact that what it shows does not fit the explanation for it's occurrence.
One theory is that the collapse of the twin towers was a result of structural members being weakened by fire and non-uniform distribution of heat leading to localised forces on the remaining structural members (those not destroyed by the plane) and subsequent buckling and then near vertical collapse - not forgetting that most of the twin towers was air.
So if you accept this theory and agree that there were multiple fires between 400-700degC in building 7, it's entirely reasonable that the structure failed in a comparable way.
Just a thought...
Posted : 11/10/2012 7:59 pm
No plane hit world trade center 7 and the damage to the structure was minimal.
So back to the footage, can anyone provide an example of this occurring anywhere else except 9/11 or explain how it can happen?
I'm open minded to all this,I just feel there's an easier way to start a war.
Shall look forward to hearing to finding out more about it.
Posted : 11/10/2012 8:02 pm
If we're on a UK forum, shouldn't it be 11/9 and not 9/11 anyway?
Where did I talk about a plane impact?
Localised heating, bad design and buckling of structural members is why it failed.
Or perhaps how the BBC reported the details of the collapse 15 minutes before it happened?
Posted : 11/10/2012 8:03 pm
Hallelujah mintman yes that could be seen as a probable cause, do you want to help me look into it?
If you think you can research how a large, complex building collapses under extreme conditions by starting a thread on a mountain biking forum you're a ****ing idiot.
Has anyone noticed that you never see the head of the CIA and Count Duckula in the same place at the same time ?
Posted : 11/10/2012 8:04 pm
zippykona if we jump from one point to another we won't really understand anything, however I am willing to go into what is proposed happened later.
mintman that was a response to an earlier post not yours, I am really interested in looking into this.
Let's start with the 400 to 700 degC as a possible reason for the collapse, so what temperature does steel melt at and how extensive was the damage to building 7?
Posted : 11/10/2012 8:05 pm
Leave my cousin Duckula out of this.
TheBrick - Member
If you think you can research how a large, complex building collapses under extreme conditions by starting a thread on a mountain biking forum you're a **** idiot.
This is a very valid post.
Then please feel free to sod off elsewhere and do so.
Posted : 11/10/2012 8:06 pm
From the BBC website on such stuff...
[i][b]Was WTC7 deliberately demolished by explosives?[/b]
In the afternoon of 11 September 2001, World Trade Centre Building 7, a 47 storey office block close by the Twin Towers collapsed without even being hit by the planes.
The building had been evacuated and there were no casualties and with so much else happening that day, its collapse was barely reported.
WTC 7 was home to local offices of the CIA, Department of Defense, the United States Secret Service and the city's Office of Emergency Management, among others.
Sceptics of the official account, including those at Scholars for 9/11 Truth argue that the building was deliberately destroyed in a controlled demolition, perhaps in order to conceal important information about a pre-9/11 plot by the authorities.
The collapse of WTC has been investigated by FEMA. Their interim report found that when the North Tower collapsed, debris crashed into Building 7.
This was the likely cause of fires which quickly took hold. The sprinkler system did not work effectively because the water main in Vesey Street had been knocked out when the Twin Towers came down.
With the intense fires burning unabated, the steel structure supporting the building was fatally weakened. But the FEMA investigators conceded that this hypothesis had a low probability of occurring.
In their final report, due to be published later in 2007, FEMA is expected to back its original hypothesis substantially - the collapse of WTC7 was accidental, not deliberate. [/i]
Posted : 11/10/2012 8:08 pm
CaptainFlashheart - Member
TheBrick - Member
No doubt you are correct, but I am prepared to have a go with the whole internet for research material and individuals who are willing to help with the research.
Totally unnecessary.
Posted : 11/10/2012 8:09 pm
Kaesae, there is a wealth of detailed techie info. out there on this already e.g. http://en.wikipedia.org/wiki/7_World_Trade_Center if you like your wikipedia. Would it not be better to start there rather than reinventing wheels although bizarrely that may actually be a more interesting subject
Edit: and who deleted my last 5 detailed technical points about what really happened?
Melting temperature of materials http://www.engineeringtoolbox.com/melting-temperature-metals-d_860.html
carbon steel is 1425 = 1540 degC can anyone else confirm this info?
mintman join in and help out with the research? this isn't about being right or wrong, it's about learning all that we can.
The footage that I've seen of the fires in building 7 were minimal and should not have caused such a catastrophic collapse, why not everyone who is interested in researching this look for footage of the fires and post it up?
Posted : 11/10/2012 8:16 pm
[quote=midlifecrashes ]Or perhaps how the BBC reported the details of the collapse 15 minutes before it happened?
www.youtube.com/watch?v=A83846Pb1-A
What [b]is[/b] the official explanation for that one?
Posted : 11/10/2012 8:20 pm
...the official explanation holds that whilst steel does indeed melt at 1,500 degrees Celsius, it loses half its strength at a much lower temperature of 650 degrees Celsius.
Also from the Beeb website, if that's your bag...
That would be roughly typical, many structural steels start losing strength @about 400degC and lose half their strength at 650degC if memory serves correctly.
Without looking at the design of the building, point of collapse and materials used amongst many other variables, this wont prove conclusive.
Posted : 11/10/2012 8:22 pm
Good grief.... Do you know anything about materials engineering??. Utterly bizarre as usual. (Kaesae I mean)
Posted : 11/10/2012 8:25 pm
Any information will add to the overall picture, how extensive was the fire damage?
marcus7 if you have something to add then add it, let's not turn this into a conflict.
 loum
kaesae - Member
Not sure you're looking for relevant info there, tbh. The steel does not have to be liquid to have lost strength and stiffness.
Anyway, interesting choice of subject again. Good luck.
A good starting point maybe to try and get your head around Euler's buckling formula for columns. It doesn't take much to put them out of equilibrium and collapse to occur.
http://en.wikipedia.org/wiki/Buckling
Interested too in the explanation for the BBC early reporting. Anyone know?
Posted : 11/10/2012 8:27 pm
OK. So it got hot, melted and collapsed. No explosives.
Why did the BBC report on WTC 7 having collapsed 15 minutes before it did so?
Posted : 11/10/2012 8:30 pm
Loum there is a lot of evidence that melting occurred in building no 7, if this is in fact the case, why did it occur?
Posted : 11/10/2012 8:31 pm
 joat
Steel doesn't need to melt before it loses its strength, it's an easy enough experiment to do if you're willing to accept the result.
Posted : 11/10/2012 8:32 pm
Loony troll!
I generally say 800 - 1200 degrees plus for a fire. Depends on the fire load, fuel etc.
Floors structure was a concrete deck on a simple pin joint lattice beam onto an external frame . Probably not a full composite deck floor construction. More like part composite action.
Fire protection was sprayed vermiculite. Used widely in the 70/80s. Maybe 90mins protection. The stuff is quite easily damaged. That means all things being equal the structure will stay there for 90mins before losing STRUCTURAL INTEGRITY !
I remember a fire at a large food store in the 90s spreading across 5no 30min fire barriers (240min protection)in 20min. The building partially collasped but consider it was the weight of a light weight roof causing the collaspe and not concrete floors above as in the WTC.
Fire engineering in tall buildings is flawed. MOE (For the troll - Means of Escape) is problematic due to the height.
If you do fire engineer you point source the fire. Having numerous floors on fire is a little more than one would have allowed for.
Note also guidance is for MOE and not concerned with Building loss. Crown Fire Standard are slighty different as you and I pay for their replacement so the Standards also require a degree of propery protection.
But hey what do I know!
Posted : 11/10/2012 8:35 pm
Page 1 / 7
