Stainless steel sink, not that old (3 years) has three separate clusters of pin size holes, all reasonably closse to each other. Is there some type of stick patch on the market or similar to stop the drip/leak and avoid replacement?
Google search - Nil
do you use a lot a bleach on it ?
I've found Araldite (the twin tube one) to be amazing - motorbike crankases - no problem sir....
ditto, stainless (particularly anything less than 22%) wont be happy with chlorides (bleach).
arrldite will do the job
Wife is bleach-tastic mad.........hence the wear!
Will source some arrldite, cheers STW'ers
Go to B&Q (or similar) and have a look in the adhesives section, there's loads of epoxy type metals and adhesives, I used some of there own brand epoxy metal on a sst tank at work and its been fine for 6+ months!
Are you sure they are rust, pinholes, or just rust spots, try rubbing them with a kitchen scourer,dont let the wife se you doing it, or youll be forced to womens tasks like cleaning,etc.
or just rust spots
uh, if it's [b]stainless [/b]then it shouldn't rust, but stainless is susceptible to chlorine compounds, so go easy on the bleach...
As above, araldite, used it on some old lead pipes, worked a treat, leak free years on
