Whilst freewheeling at slow speed on perfectly flat tarmac last night, the rear tubless tyre spontaneous unmounted accompanied by gun shot like noise that almost had me diving for cover. Luckily it happened on smooth tarmac at low speed but I shudder to think If it had happened on a high speed descent somewhere.
Anyone else had similar experiences?
Is the tyre now knacked and stretched and should be thrown out?
Tyre/rim in question was a Kenda nevegal UST 2.1 on stans flows with rim tape at around 40psi.
JRA if there ever was one. You sure you weren't hucking off your garage roof? 😉
Old tyre? Installed recently?
I reckon it may have stretched the bead... is it back on ok and seated properly?
have had this, inflated to about the same then one hot sunny day.. bang... tubeless jizz everywhere... one nobby nic, stretched bead... in the bin.
I had one go in the back of the car on a hot day - had to peel the gunk off the windows once it dried, and the car still smelt a bit fishy fpr ages. The tyre bead was damaged so it's a right-off unless I stick a tube in it - if your bead is damaged it's pretty obvious.
im due a big kick in the nuts from tubeless.
since going 819/lust or TR i have happily survived everything the chilterns can throw at me (thorns and flints) up to and including a 4" nail.
last night we stopped for two punctures, ok so one limped to the pub, and one was only noticed when we had bought beers..... I was being a smug **** pointing out i had a spare tube that i wouldnt need cos i dont get punctures.
the gods will punish me
It had been on there for 4 months probably, 3 of which it wasn't even used. It wasn't a new tyre for sure but It had plenty of tread left and the sidewalls were not worn.
Not tried yet, the bead has gone a little wavy now though so maybe that means it knackered.
Isn't it the Flows that have a sticker on them saying don't inflate above 32psi (or is it 38?)
There's been a few threads where people report tyres popping off at higher pressures. It seems that Stan isn't being over-cautious here.
Hmmmmm around 40psi on a stans with a 2.1, right on edge of stans limits there. Did you use a compressor to mount or pump it up higher to get the beads to seat propperly when originally installed?
You mean the one I peeled off 😉
I used a track pump to seat the tyre. I'm not sure I trust the pressure guage on the track pump though which might be the culprit.
No Tubes rims seem to have barely any hook for the tyre bead. I was ogling the Hope Hoops in CycSurg yesterday and was genuinely shocked. Had a chat with both the sales wallah and the mechanic who said that they've a reputation for shedding tyres and in their opinion they were best avoided.
I've used stans rims for years and not had an issue with them, user error and the inability of blokes to read any form of instruction seems to be the main issue
This has happened to me so many times, it nearly scared the heck out of my missus when it went off in the car just behind her head.
Best thing is to get another tyre, chances are the bead has gone.
Buy a UST rim????????
too much pressure. More importantly, why do you have 40psi in a tubeless tyre?
I had one BANG! when it was off the bike laid on it's side in the Sun. (Had been riding for 2 weeks on it to work with no issues)
Admit I had the pressure up far too high. Bead was ruined
scared me half to death too - I was fiddling with the frame right next to it at the time
Admittedly I would normally run about 35 but I'm only cycling on roads/tracks at the moment as just out of knee surgery so bumped up the pressure a little. Also at over 13 stone stone at 35 psi I've managed to pinch puncture a UST tyre a fair few times.
seems to be a common theme of "in the sun". Pressure goes up with temperature if volume is constant...
Meanwhile in California and other hot places riders wheels explode every 5 mins.
It is not a heat thing.
There is a sticker on the flow rim that advises on what pressures for what width tyres.
I killed 3 schwalbe tyres when i first went tubeless, blowing off of the rim and damaging the bead. Get shot of the tyre i would advise
