So what are the big...
[Closed] So what are the big honkin 29ers then?
[#5912098]
Making a list and checking it twice... Not neccesarily about wheel travel or whatever, just about intent- so the Prime is a little shorter travel frinstance. Just flat ruling out anything steeper than 68 degrees though, it's 2014. Missing any?
Banshee Prime
Canyon Spectral
Commencal Meta AM 29
Cube Stereo 140
Intense Spider Comp (but not the normal spider)
Kona Satori (discounting the process, too short travel)
Nicolai Ion 15
Norco Shinobi
Orange Five 29
Santa Cruz Tallboy LT
Specialized Enduro
Transition Covert
Yeti SB95
I'm considering buying used so the more contenders the better 😉 Think the Transition is currently top of the heap though
Posted : 01/02/2014 10:21 pm
In true Stw fashion I'll suggest what I've got- Turner Sultan. Taken it down a few BPW blacks and the rider was definitely the limiting factor
Posted : 01/02/2014 10:36 pm
BMC TF01 Trailfox
Posted : 01/02/2014 10:51 pm
For the price of a frame these days you could a) get a custom build b) buy a welder and build one your self.
Though the countless hours currently spent playing with suspension kinematics on CAD has made me appreciate a well designed frame.
Posted : 01/02/2014 11:02 pm
 mboy
Pyga 110?
Salsa Horsethief?
Just ordered myself a cheap Ghost AMR 2955 from CRC, only 100mm at the back (doesn't need more IMO), 110mm up front and 69 degree head angle, but low BB means a 120 or even a 130mm fork should be a goer bringing the head angle to about 68 degrees.
Was looking at the Banshee at Core bike show, looks good, but not sure a 29er needs that much travel myself...
Posted : 01/02/2014 11:03 pm
 Andy
Sultan +1
Posted : 01/02/2014 11:09 pm
Niner WFO
Niner RIP
Posted : 01/02/2014 11:10 pm
If you're open to hardtails I'd look little further than German 2souls!
Posted : 01/02/2014 11:14 pm
I know you have the Enduro , but I'd put the Spech Stumpy FSR Evo on the list. Possibly Transition Bandit as well?
Posted : 01/02/2014 11:18 pm
Cheapey cheerful, crc's Vitus Escarpe 29er.. Oops only small un's left
Posted : 01/02/2014 11:23 pm
Hardtail could only be the awesome 2 souls quarterhorse.
So good to ride I'm tempted to take to Sierra Nevada instead of my Tallboy Ltc.
Posted : 01/02/2014 11:24 pm
Sultan +2 🙂
Posted : 01/02/2014 11:47 pm
Some good ones in there, cheers!
If I do this, it's to replace a 160/150mm 26 inch full suss with coil lyriks so definitely not going to a short travel 29er, or anything too xc- needs good tyre clearance etc. Rules out quite a few. Even with the 68-degree head angle crowd I'm trying to avoid anything that won't take an angle headset if need be, as I likes me the slack.
That Escarpe's crazy value, wish it fitted! I'd be tempted to just grab one.
Er, what else. Horsethief, BMC and WFO are great calls, cheers! Stumpy is eliminated for gobsmacking ugliness, Pyga for its ridiculous seatmast. The RIP9, Sultan and Bandit don't push my buttons, all seem a bit xc.
Posted : 01/02/2014 11:56 pm
Krampus
Posted : 01/02/2014 11:57 pm
Why 29 and not 27.5?
Posted : 02/02/2014 12:08 am
Cos if I'm spending a grand and a half on changing frame, wheels, tyres and forks, I want a difference I can actually see 😉 Other option o'course is just to buy another 26 inch frame and write 650b on the tyres in tippex, nobody'll know.
Posted : 02/02/2014 12:10 am
The Sultan is a trail bike, it pedals well but really isn't XC
Posted : 02/02/2014 12:19 am
Oh and the mbr review reckons you shouldn't discount the process 29er due to travel, they're supposed to be the shiz!
Posted : 02/02/2014 12:22 am
KRAMPUS
Posted : 02/02/2014 12:23 am
The single ring thing puts me off the process too... (not that I'm against single ring, but options are good... And it makes for a rather expensive bike)
I rode a Sultan and I will not comment on that experience here because there are fans present who're taking time out to try and help... but no ta!
Posted : 02/02/2014 12:25 am
bigdean - Member
PMSL as most people would have no idea what would make a custom frame any better short of - copy that please (which would probably turn out more expensive) and the thought of buying a welder and then learning to weld 🙂
Anyway the Tallboy gets a very good write up and the missus is very made up with hers so I reckon the LT would be good 🙂
Posted : 02/02/2014 12:30 am
mikewsmith - Member
That is totally what I would do 😆 I can weld- well, I can stick bits of metal together with birdshit well enough that they don't break under their own weight- but I couldn't weld a bike, or cut the tubes, or any of that useful stuff. Think I will leave it to the experts.
(if I was customming something, it'd be a new longer slacker front triangle for my Hemlock, but I digress)
Posted : 02/02/2014 12:33 am
Sultan rider here. IMO it's a trail bike. Not stiff enough for hammer-time use and its not slack enough to meet your spec anyway is it?
Built chunky, it gives a good account of itself, but I don't think it has the correct suspension characteristics for big stuff.
I'd be interested to hear why you didn't get on with one North wind.
Posted : 02/02/2014 1:06 am
My default mode is unconstructive slagging so I'll wind it in- it just felt tall and steep, very old-school American. Pedalled amazingly for a 125mm bike, but then I thought, why is it a 125mm bike in the first place? That's a lot of travel for a 29er, and it looks pretty sturdy... but it could be shorter and lighter without giving anything away. I didn't know the geometry but looking at it now I see long chainstays, short reach, highish bb, steep head angle...
Posted : 02/02/2014 1:26 am
Hmm, how did I not know about the Cube Sting? Exact same geometry as the Stereo, but prices starting from £1800- cheaper build and all alu frame mind.
Posted : 02/02/2014 3:19 am
 JCL
Well if you had the funds the TF01 is the way to go. Stunning details, perfect geo and the rate is supposed to be perfectly linear/progressive. I would have gone that way if I could have got one at anything like what I can get a Specialized for but no chance so E29 it is.
What I would do if I was you is buy the Comp E29 bike and get some Derby rims and eventually Pike/XO1. That combo would stuff a stock carbon E29. The rear suspension is so much better than most bikes that it'll still be fine with the OE shock.
Posted : 02/02/2014 3:54 am
ill suggest the two i have, both by Titus
ti fireline evo 29er fun bike and seems to be able to do everything well
http://www.on-one.co.uk/i/q/CBTIFLX9/titus_fireline_sram_x9_mountainbike
and titus carbon rockstar, cant comment on how it rides as i only finished building it last night, i built frame only up, so im sure you would spec up in a few areas
http://www.on-one.co.uk/i/q/CBTIROCKX5/titus_rockstar_sram_x5_carbon_mountainbike
and dont forget fat bikes are 29ers as well 🙂
Posted : 02/02/2014 8:16 am
I'd check your ERD if I were you, you've been short changed
Posted : 02/02/2014 8:29 am
I'd love to buy a tig welder and learn, new frame is an excuse but its not for everyone granted.
Options was asked for and yes what does make a good frame?
R.e. copying- the covert looks good on paper just short (as per other thread) so just "copy" that and add 1.5" to the front triangle?
I've been reading and looking a suspension designs for a while now and still not past the 2d wire frame stage. Getting to grips with balancing chain growth, travel is difficult but in an ineresting way.
Anyway i just want my 5 spot in 29" form (140/150 travel), unfortunaly thats not the sultan and the burner is not worth the swap, same as OP not wanting 650b.
Posted : 02/02/2014 8:34 am
I've got a bit of a thing for a Devinci atlas at the moment. Only 110mm travel frame, but will take up to a 140mm fork.
Also has reversible linkages that slacken and lower the geometry.
I've not ridden one, but good reviews and they look nice, which is as thorough a basis as most STW reccomendations...!
Posted : 02/02/2014 9:24 am
not sure what ERD means
maybe i should have said that fat bikes can be 29ers, maybe i should have said "can" be 29ers as the majority of fat tyres are almost identical in size to a 29er diameter
and a krampus can be both
Posted : 02/02/2014 10:23 am
@northwind - fair enough, horses for courses etc.
*takes ball and storms off home sulking*
Posted : 02/02/2014 10:25 am
Intense Carbine or Spesh Enduro are the only two even remotely likely top tempt me off my Stereo140.
Posted : 02/02/2014 10:29 am
Effective Rim Diameter, fat bike rims are 26" 29+ rims are 29"(approx)
Posted : 02/02/2014 10:57 am
Spech Enduro is the only on on my want list, coming from a short chainstayed 29er HT myself
[url= http://www.pinkbike.com/u/mikelevy/blog/Pinkbike-Gear-Awards-The-Winners.html ]Pink bike[/url]
[url= http://www.vitalmtb.com/videos/features/2013-Bike-of-the-Year-Vital-MTB-Shreddy-Awards,24356/sspomer,2 ]Vital [/url]
Both gave bike of the year.
Posted : 02/02/2014 11:09 am
Niner WFO9 looks big and honkin
Posted : 02/02/2014 11:12 am
Yeah, the WFO definitely makes the list.
Posted : 02/02/2014 7:42 pm
You're more than welcome to try my Meta AM29, it truely is a beast, destroys trails. Heavy though, but built to last.
Posted : 02/02/2014 8:03 pm
Ordered a Horsethief - you're welcome to a go if you like? I'm based in Glasgow - you're in the east - aye?
Posted : 02/02/2014 8:23 pm
For those who can't see the point in long travel 29ers, don't knock them till you've tried them. Long travel 29ers make complete and utter sense, great fun. Went out on mine today after a month and a half off it and even though I was taking it easy as I've been off it for a while I had a hoot. Yes you can use them in steam roller fashion if you want, but that misses the point, they just make you want to hunt out bumpier terrain.
Posted : 02/02/2014 8:39 pm
 IA
For similar use I've a horse thief with 140mm bombers on, chain guide etc. Goes like the clappers. Handles like my old DH bike, take from that what you will....
Posted : 02/02/2014 8:41 pm
Cool - 140 Pikes going on mine - looking forward to getting it going...
Posted : 02/02/2014 8:54 pm
Holy balls, you can get an end-of-line Horsethief 3 for £1150. There's a lot I'd want to change in there but holy balls nevertheless. And it looks like a bike, too, not like a tool for removing rocks from hooves like some of the others. Wee bit steeper than I like and the chainstays are a mile long but still.
Cheers for the offers of rides- Weeksy yours and Doug's reviews of the Meta is what got it on the list, think we're quite far apart? It doesn't seem that outrageously heavy to me tbh, and more importantly it is as yellow as ****. Sillyoldman, there is a chance I'll take you up on that- but I don't want to bother you right now since I'm still figuring out what to do, but much appreciated.
Posted : 02/02/2014 9:05 pm
New and old Horsethiefs are entirely different beasts.
No worries re a ride - email in profile. Drop me a line any time.
Posted : 02/02/2014 9:37 pm
Yeah, I see the 2014 is all change. I'm assuming IA's is the outgoing model though?
Posted : 02/02/2014 9:39 pm
Page 1 / 3
