Hi,
Has anyone built a Peregrine with an Alfine? I'm in the process of building mine with an Alfine 11 speed. The chainline on the alfine seems very narrow at about 42mm. I am trying to recycle an FSA compact chainset using the 34 tooth smaller ring only. Ideally I'd have liked this on the outer position. Looks like the 34 tooth ring I want to use should be near the line I need in the inner position, but this is going to look pretty cack with no ring on the outside and probably some washers to space out the chain ring bolts.
One crazy thought I had was to buy another 34 tooth ring and try and find a machine shop to cut down the old ring, removing all the teeth and fitting this on the outside like a bash ring covering the outside spider arm cutouts and negating the need for washers on the chainring bolts.y
Anyone have any good ideas or maybe pics of your Alfine installed?
Many thanks
