Current rack has had a bit of an incident so I need a new 'un.
Genesis Day01 Alfine 11 with Avid BB7s.
What you got on yours?
You need pics to choose a new rack?
Seriously?
Simply because, having looked over previous threads, there's a lot of talk about Tubus and Tortec racks which I know for a fact won't fit my frame.
So I actually want to see one physically attached to a frame before buying.
It can be a real bastard getting a rack to fit on some disk-equipped frames. The Super Tourist DX seems to avoid most problems though. I tried a Tubus - with disk adapter - on my VN Amazon and it just wouldn't fit.
Tortec won't fit? How not?
Try Topeak or Blackburn.
Do you have an lbs to ask for advice?
Aye, LBS advice was a Super Tourist DX, but I'd like to look at some other options.
The Blackburn disk-specific one fits much like a Super Tourist too.
topeak do not that pretty disc friendly racks. although oddly the non-disc version is the only one that fits my 456. The disc version is on my v braked hybrid.
My pompetamine, rack, mudguards and panniers arrive tomorrow. I'll post some exciting pictures then... 8)
Stoner - Member
700c CHECK
Rohloff CHECK
BB7s CHECK
No rack but the pompetamine will take one
Aye, but which one? 😆
sc-xc - Member
Which ones did you go for?
Blackburn something or other - it was on special at on one
I have a rack on my derailleur geared disc road bike, but I guess that's not relevant 😛
You've got me thinking now. I bought [url= http://www.on-one.co.uk/i/q/RABLMTN1RPRACK-BLK/blackburn_mtn1_rear_pannier_rack___black ]this rack[/url] - it says it is the 'Original and best selling mountain rack for rear use'
Would a 'mountain' rack fit the Pompetamine? - this may be a stupid question, but I am new to racks.
I understand there is only one set of holes, and I intend to run SKS mudguards - so a bit of bodging will be required.
I tried to fit SKS mudguards on my Genesis. Good luck 😆
The problem is usually that the rack struts foul the disk caliper, but this is very frame specific. The Super Tourist ( and the disk-specific Blackburn rack) have a stand-off arrangement to prevent this happening. FWIW, I managed to fit a standard Blackburn rack to an Inbred just by using a couple of thin washers as spacers.
Will the 700cc wheels be a problem? Are racks different heights?
They can be. Trying to fit a 26" rack over SKS mudguards might cause an issue with tyre clearance. If it's a Blackburn (or a copy thereof) you might be OK.
Ah well. It was only £15. I guess that's me shopping tomorrow then. 😐
If you are going to be carrying a decent load then it's worth getting a good rack. If you are going for panniers, then one that has the additional rear struts is also a good idea.
Yeah, Druidh that's what I'm after.
Don't have any photos of my bike, but [i]I think[/i] this is what it looks like.
Actually, no it's not. Not at all.
No hub, does that matter?
[url= http://farm8.staticflickr.com/7106/7035837191_3ac99930a1_o.jp g" target="_blank">http://farm8.staticflickr.com/7106/7035837191_3ac99930a1_o.jp g"/> [/img][/url]
Tortec Apex, the whole side slides out as wide as you want it. But have to attach my ortliebs to the top bar to avoid heel chaffing.
I can confirm a pompetamine with alfine 11, mudguards, avid elixirs and and a blackburn ex1 rack work fine (so sc-xc yours looks ok) - can take photos tomorrow if you need
Edit soz didn't realise sc-xc yours is a different model, it looks the same but confident prediction retracted!
Brill, cheers. Getting excited now....!
Looks a useful bike that Kaffenback.
What tyres are you sporting Stoner?
Cheers.
@trailrat can you post some close ups of your rack fitting around the caliper/braze ons please? Ta.
35c small block 8s.
Ta. Is that a long set screw and a few nuts as spacers? Doesn't look like you needed any on the drive side?
For aesthetics you do of if your running a fat tire.
I always equalise them to center the rack anyway cause im anal.
Its a long screw and some vbrake spacers ( all a disk compatible rack is is a rack with a spacer built in)
Sorry everyone, this has turned into a 'fitting racks to Day One's thread 🙂
You said you could get 35's on yours.... They must be a bit undersized? I couldn't get anything bigger than 25's on mine (Pasela's and Marathon's) with SKS narrow guards. The top of the fork bridge being the main offender so I can't see a way around it.
TR have you had much weight on it? Doesn't look the strongest to me.
CA, do you mean a long m4 set screw cantilevered like it is? I don't likely the look of it either but mine won't carry any real load, just local one pannier stuff. Could always use Grade 8.8?
Ferkin glitchy shitty slow site
Toured shetland , orrkney and back to scotland no bother
If it comes loose its ****ed. But good maintainance 🙂
Mines does the weekly shop on the road rat snd i even took a months worth of off shore gear home from work on it after a short notice check in .
Infact. Jayne did 5 months touring new zealand on and off road with it fully loaded with camping gear with the same rack on a kona dew disk.
I had cantis
Neither had any issue with the racks
If a rack bolt works loose your boned . Itll see high dynamic loading.
Id be looking towards that for issues ..... Or cheap stainless bolts supplied with most racks - the shiny silver ones !! I prefer nice hi tensile surface rusty bolts anyday.
Never had an issue with a single rack ever and as far as i know none of my customers did either Also try and stick a nyloc on the back if possible to prevent it coming loose but with modern deraileurs this isnt always possible.
Could be the bolts right enough.
The end is still stuck in my 29er frame 😀
I always use grade 8.8 for the bottom fixings with a bit of thread lock. That kills both potential problems at source. I have a Tortec Ultralite rack for my Day One, just haven't fitted it yet as I've been using an old MTB to commute with and that's already fully sorted.
