shimano STI compata...
[Closed] shimano STI compatability question ?
[#4635592]
my 5 yrs old 105 STI's have died, or more to the point the left one has. Can I replace with the newer 5700 levers ? I realise I will need to recable etc
Posted : 09/12/2012 12:42 pm
Yes.
(assuming your old shifters are 10spd? Can't remember when they went from 9 - 10)
Posted : 09/12/2012 12:44 pm
simon, yes old ones are 10, with a double on the front. Wiggle have the 5700's at £150 a pair, so think will have to bite the bullet..
Posted : 09/12/2012 12:46 pm
thanks Simon - ordered, RH one going on classifieds shortly ! LH one in bucket 🙁
Posted : 09/12/2012 1:11 pm
let me know about the RH STI please...
simonbowns@me.com
Posted : 09/12/2012 1:13 pm
simon just mailed you (crappy phone pics, and just going out till this evening, but if you are keen I can get some decent pics later on)
Posted : 09/12/2012 1:17 pm
You could just stick a new main lever assembly in the left lever.
Posted : 09/12/2012 1:37 pm
Isn't the front mech and brake cable pull different on the 5700s...
Posted : 09/12/2012 2:30 pm
A bit, but all seems to work ok 🙂
Posted : 09/12/2012 2:47 pm
Mister P - Member
It's the ratchets that are knackered so I don't think the lever assembly would sort it. Just hoping that the 5700 STI's will work with 5600 mechs
Posted : 09/12/2012 6:20 pm
I've replaced my ultegra 6600 shifters with 5700 105 shifters due to crash damage and the shifting is fine, but the braking seems a bit weak, the pads need replacing so hopefully will improve
Posted : 09/12/2012 6:29 pm
Just to try it... lots of WD40 may help. Or petrol to de gunk then WD
The lever assembly replaces all the ratchets. If it is a 5600 lever there was a known fault with them so you may get it swapped for free if you speak nicely to the shop you got the levers from.
Posted : 09/12/2012 6:38 pm
thanks. I am using Tektro Canti's so brakes will hopefully be fine. Mechs are the old 5600's though...
Posted : 09/12/2012 6:39 pm
Found a pair of 5600 sti's on Amazon so can now replace like with like :). thanks all.
Posted : 09/12/2012 7:36 pm
