seating fat bike ty...
[Closed] seating fat bike tyres
[#6382332]
Recently bought a Fatty from On One. Floater tyres and standard rims etc.
First time I rode the bike the front tyre "burped" off the rim. Second time out and both tyres have developed a flat spot. Not the best way of describing it but as the wheel turns it looks as if there is a buckle in towards the centre of the wheel at one point on the rim. Wheel is fine so it looks like the way the tyre is seating in the rim.
I have taken the tyre off and moved it around the rim but am still getting the flat spot around the valve area. Is there a specific way of seating fat tyres or has anyone else had a similar issue? Would be interested in how you sorted it out.
Posted : 03/08/2014 9:27 am
Using tubes or tubeless? If tubes, the flat spot maybe due to the fact that the rubber is thicker near the valve, so inflates to a smaller diameter.
Posted : 03/08/2014 9:35 am
Yep tubes in. Inflated to 40psi to try and seat them but still had the flat spot. Tyres do not seem to be sitting in the rim properly?
Posted : 03/08/2014 9:49 am
Daft question, but are you pushing the valve well into the the tyre to allow the tyre to seat in that area before inflation?
Posted : 03/08/2014 10:02 am
When you say "flat spot" do you mean they feel a bit egg shaped?
If they are egg shaped cure them like this
Deflate the tyres.
Spray silicon spray or similar or soapy water around the bead area.
Inflate to 40+ psi.
Leave overnight.
Lower pressure to what you want.
Sorted
Posted : 03/08/2014 11:06 am
look around the rim - you can tell whether the tyre is seated properly by whether the line above the bead is at a constant distance from the rim all the way round.
Posted : 03/08/2014 11:24 am
This stuff is brilliant. Fit tyres, squirt on tyre/rim bead seating area, inflate to 20psi and jobs a good 'un.
Lower pressure to 8psi before you go ride though.
Posted : 03/08/2014 11:45 am
Thanks for the advice. Used soapy water and they went straight on. Egg shaped was a better description.
Will look into some silicon spray as well.
Ian-r
Posted : 03/08/2014 11:52 am
