Secondhand there seems to be more choice now for decent 650b forks whereas 26" forks are maybe becoming long in the tooth? (I don't want a wheelsize debate- both are awesome).
Apart from the extra axle to crown height whats the difference?
Ultimately I'd be swapping my 26" rim for a 650b one but for now are there any downsides? Axle to crown is 554mm which is almost identical to 26" Marzocchi forks that I also own.
I don't see a prob? Maybe abit more 'space' between the brace/tyre.
YOU WILL DIE!!!*
*(You'll be fine)...
I've noticed a glut of second hand 26 and 29 er forks recently but only a few 650B cropping up, new is another matter, but still seems plenty of choice second hand.
Apart from the possible (depending on make/model) mild increase in A2C height there's nothing much worry about. I'm sure a few 650B forks are using a different offset now so could be worth paying attention to that but they'll still work.
20mm difference so about 1degree slacker?
150 Mazz 26" are c535mm high, 160 Fox 34's 554mm so no biggy.
Will your downtube have clearance for front wheel when bottoming out forks?
Shirley you'd have more clearance?
The bike does look alot 'taller' though- is that a fair comment?
650b forks are (to generalise) slightly longer, but have more offset. So the geometry theory is that you'll have a slacker head angle but the offset should speed up the handling and "cancel it out". The end result is a very slightly longer wheelbase. At the end of the day, and talking to people who have done it, you can't even tell the difference.
if it's longer in the leg and and shorter in the torso you probably want a large.
of course it looks taller you've put a longer fork on it you spaz!
quality comment
i thought you "mazz" were the best forks ever, always state that on pike threads. Fox 34 though - LOL
#toopoorforpikes
Rob & Hora, I think you need to get a room, or a least go for a mince round the Peak together 😀
I think the angle that i took that^^^ photo from of my Zesty makes it look shorter/taller, than it actually is. In the "flesh" so to speak, i don't think you'd even notice it had a 650B fork on it etc
I was initially slightly concerned the fork lower "hoop" that wraps over the top of the tyre might look silly if it had a load of fresh air under it, but certainly with "Big" 26" tyres like those HansDampfs it looks fairly normal. With a more XC flavour small volume tyre it might look like a bigger gap, although that means there would be plenty of space for a mud deflector etc! 😉
I also thought that if the front feels too tall, then i'd just fit a 1 deg angle set which would lower the front back to where it came from
It just looks like Fox 36s always look, you wouldn't even question it.
#toopoorforpikes
I'm not a RS fan. I'm Mazz and Fox regardless.
