Road disc wheels - ...
[Closed] Road disc wheels - Any lightweight budget options?
[#8322796]
I am looking for a spare set of wheels for my CX to use for longer road rides and was wondering if anyone has any decent options?
They need to be 15mm & 12mm bolt through and have a freehub that is compatible with Shimano 11 speed road cassettes.
The best I've found so far are the Merlin build of chosen hubs on Alex 1.9 rims which are 1601g @ £195.
They aren't in stock but are there any others I should look at in a similar price range (up to say £250)?
Posted : 31/01/2017 3:15 pm
Those Kinesis ones? Might be over budget.
Posted : 31/01/2017 3:20 pm
DT Swiss R24 are always kicking about cheap/
Tubeless too
Posted : 31/01/2017 3:23 pm
Looked at Kinesis but they are heavier & more expensive. Designed for CX so will undoubtedly be more robust, but as these will be strictly for road rides I can get away with a much lighter setup (24 spokes for example).
I'll take a look at the DT Swiss sets.
EDIT: They are a bit heavier @ 1700g a pair. Was hoping to get below that but I'll add them to the list.
Posted : 31/01/2017 3:36 pm
I have a set of the DT Swiss R24 and they have taken a proper beating. I've ridden them for 18 months in all sorts of weather and hit all manner of potholes. They haven't complained at all and are still running nicely.
Posted : 31/01/2017 3:43 pm
Mason x hunt disc ones. A bit more than the budget but mine have been great.
Posted : 31/01/2017 4:11 pm
Thanks, looked at those and the Novatech CXD but minimal weight saving for the cost as they are aimed at CX with higher spoke counts which I really don't need.
Posted : 31/01/2017 4:18 pm
I've got the Cosine ones which are great but seem to be discontinued. Might be able to pick some up on eBay though?
Posted : 31/01/2017 4:22 pm
Haven't there been a few advertised/won awards recently super lightweight?
Posted : 31/01/2017 4:38 pm
I was looking at the Cosine ones but as you say, can't find a disc version. What are your called specifically (for ebay search)?
Posted : 31/01/2017 4:46 pm
Dave. Sorry 😳
No they are (rather catchily): [i]COSINE 23mm Alloy Clincher Disc Brake Road Wheelset[/i]
The old listing is [url= http://www.wiggle.co.uk/cosine-23mm-alloy-clincher-disc-brake-road-wheelset/ ]here[/url].
Posted : 31/01/2017 4:52 pm
*Yours
Thanks 😀 Much appreciated.
Posted : 31/01/2017 4:56 pm
The R23 DT Swiss ones are lighter (lighter hubs, same rims) but a little pricier.
They're what I have on my Rose Bike. Very good. We'll put together and no issues either riding in trails or riding all through winter with no cleaning or maintenance
Posted : 31/01/2017 6:28 pm
Cero ARD23 are 1500g for £285, if they're still on sale.
Posted : 31/01/2017 6:43 pm
Just Riding Along's Jawbones on Pacenti rims. More than budget admittedly but nice and light. I have the non disc ones.
Oh...Not sure if bolt through versions available ..
Posted : 31/01/2017 8:01 pm
+1
I've had a set of the R24's for several months and they've seen some rude terrain yet my 15st+ still hasn't thwarted them - pretty much bang on £200 too. I needed 12mm axle back AND front which limited my choice somewhat.
Posted : 31/01/2017 8:51 pm
Eyeing up the Hunt ones at £250 - not sure how the compare to their more expensive offerings but seem like a bit of a bargain.
Posted : 31/01/2017 9:05 pm
Yeah I've seen the JRA as well. All more expensive than I'd like.
Posted : 31/01/2017 9:27 pm
Anything at Superstar? Isn't it the last day of "monster50" promo code?
Posted : 31/01/2017 9:42 pm
T that I could find, most of their clearance hubs won't take an 11sp road cassette.
I'll double check.
Posted : 31/01/2017 9:55 pm
Gah, just as I was gonna order the Cero ARD23s then bump the price up to £350!
Posted : 01/02/2017 6:41 pm
I got a set of alex rims ATD470 on switch ultra hubs from superstar in a clearance sales, 1650g £149 and I've done thousands of Ks on them including loads of off road
Posted : 01/02/2017 8:28 pm
Switch hubs aren't compatible with 11spd road cassettes according to the SS website.
Posted : 01/02/2017 9:21 pm
Something wrong there, as I'm looking at the hub right now and it says 'switch ultra 11spd disc' on the hub and it's got a 105 11 spd cassette on it
Edit: worked it out, I'm using the ultra-lite rear hub which is compatible, should have been more specific
Posted : 04/02/2017 2:41 pm
Thanks jonnyboi, I'll check the ultra lites out then.
Posted : 04/02/2017 6:45 pm
Hmmmm both of the cheaper SS ones are seriously heavy so there's better options for what I want.
Think I'll wait for the Merlin ones to come back in stock but thanks for the suggestions.
Posted : 04/02/2017 10:15 pm
I'm looking at the Cero ARD23s too, look to be very competitive on price at £285 which they often move to.
Posted : 14/02/2017 1:58 pm
 Olly
Build some? fast rolling cheapy xt hubs built into the budget road run of your choice with race spokes. Cheapy Chinese carbon rims?
Posted : 14/02/2017 2:32 pm
XT hubs are indeed fast rolling and cheap, IMO, but not road 11-speed compatible.
You could still use an XT front, of course, but for a Shimano rear you'd need the FH-CX75, which isn't that cheap, or the FH-RS505, which isn't terribly light (nor available with fewer than 32 holes).
So you're onto looking at the same Novatec/Chosen/Bitex rear hubs as most of the Far East pre-built wheels, except the sum of the parts would probably cost you more 🙁
Posted : 14/02/2017 3:40 pm
