Had two Scenics and a Clio. The first Scenic was alright although the electrics started to play up just before we sold it. Wouldn’t start, took it to the dealership, said they couldn’t tell waht was wrong and next time it wouldn’t start to bring it in 🙄
The second Scenic and Clio were nightmares. Cost us a fortune in repairs and depreciated to nothing in four years, we’re still. Minor things like air con etc failed quite quickly, the Clio regularly broke coil springs and needed injection coils replacing, also had an airbag go off when it shouldn’t, took Renault nine weeks to sort that (during the repairs they destroyed the dashboard, blew all the head lights and damaged the ABS system. The Scenic out did it though when it sheared the end of the drive shaft off. (don’t forget the Clio bonnet openning saga which Renault blamed on drivers not servicing the bonnet catch).
I will never never touch a French car again. Have a Honda CRV and a Volkswagen Touran now, the CRV has givn us no problems in 5 years (and does get used a bit off road), the Touran’s only two but has also been fine. If you’re looking for a mega load carrier you could do a lot worse than a diesel Touran, planty about as well.
