I need to remove the rear shock and send it for a service, but a little unsure of which bolts to undo. I have loosened the two main bolts at either end of the shock, but do I need to undo any others on the end of the link?
Posted : 30/08/2010 12:58 pm
You need to undo them all as you will have trouble pulling the shock from the swing.
Posted : 30/08/2010 1:01 pm
Ok, thanks. Will go and give it a try!
Posted : 30/08/2010 1:07 pm
