Removing cranks fro...
[Closed] Removing cranks from a square taper BB...
...once the threads in the cranks are stripped. 😳
Ideas please...?
Posted : 30/07/2015 9:42 am
Desructive (tocranks and your nuts!): undo or even remove bolts, ride around and pop off kerbs until crank loosens and falls off. You will trash the tapers on the cranks but possibly not the bb.
I have also heard folk using car bearing pullers but you would need a smallish one i guess.
oh also if crank is alloy (which square taper ones aren't tbf) then its a 10 minte job to dremel a slot in the bit where it meets the bb spindle and then use a big flat screwdriver to prise it open a bit till it drops off. obviously also destroys the crank!
Posted : 30/07/2015 9:45 am
angle grinder/saw and cut through the crank arm.
a hub puller might do it if you can get one that'll grip the arm.
or just ride the bike round for a bit without the bolt in place - it may free up.
Misrule of thumb:
Posted : 30/07/2015 10:04 am
Thanks - not worried about destroying the cranks as they are going in the bin.
Posted : 30/07/2015 10:06 am
wwaswas - Member
i'd be amazed if this didn't work.
(but you may be riding around with 1 crank for a few minutes)
Posted : 30/07/2015 10:08 am
 Gunz
Heat up the crank at the interface then come at it from the other side of the frame with cold chisel and mallet.
Posted : 30/07/2015 10:10 am
riding around should remove it. or you could use a mallet and try whacking it until it pops off the axle. might take you a while and beware flying crank arms
Posted : 30/07/2015 10:12 am
I thought of this but was worried about what stresses such effort would put through the frame. Its a cheap frame I guess (Defy) which I am upgrading so I guess if it breaks I just divert to Planet/Ribble for new winter one.
Posted : 30/07/2015 10:29 am
Secure crank arm in a vice then **** the end of the axle with a big screwdriver/chisel and a mallet (make sure you have someone to hold the frame when it pops off).
Posted : 30/07/2015 10:31 am
ahwiles - Member
wwaswas - Member
Be amazed. The LH crank may fall off, the RH one won't.
hacksaw/chisel the easiest IME, hitting things with a big hammer when a light alu frame is connected is not the best idea IMO, and takes massive hits, if it even works at all.
Posted : 30/07/2015 10:33 am
As above, we always just rode a bike for a bit if they were stuck, particularly if you're going to bin them anyway. A couple of kerb hops usually sorts it.
I have hacksawed through a crank arm before (blade only - too ages...) but that was a desperate case and properly corroded on.
Posted : 30/07/2015 10:35 am
Ride it or use a cold chisel and a hammer against the back of the area of the crank around the BB axle.
Posted : 30/07/2015 10:43 am
^^ flywheel puller FTW
Posted : 30/07/2015 10:46 am
i did this many many years ago. i didnt have a crank puller tool and couldnt be bothered to take it into the shop to have it removed.
took me about 30 minutes of whacking it and cursing it but it finally flew off (literally). i rode the frame (alu) for another couple of years using the same cranks. had no problems so you should be fine so long as you're careful
IIRC i used an old seatpost between the bottom bracket shell an the top of the crank so more of the impact force was near the axle itself
Posted : 30/07/2015 11:04 am
Angle grinder in line with one of the faces of the square taper will see you right and take about 5 minutes.
Posted : 30/07/2015 11:10 am
Just spent 15 minutes hammering to no avail. Off to get the hairdryer...
Posted : 30/07/2015 11:14 am
You can get an angle gridner for about £20 - and you know you'll use it again...
Posted : 30/07/2015 11:40 am
Oh and boiling water is a good way of getting heat on if you don't want to use a blowtorch.
Posted : 30/07/2015 12:17 pm
I'm at my wits end now.
I've heated with an hairdryer and hammered with chisel a lot - no movement either side. I've attacked the no drive side with a hacksaw which appears to want to take about 24hrs of sawing and bent the chainrings accidently with a swing of a mallet.
Now the bike is unsuable and an embarrassment to take to the LBS.
Help!
Posted : 30/07/2015 12:45 pm
It has taken me an hour and a half of battering in a bike shop before. It will take a long time.
I'd jump up from hair dryer to kettle. Failing that then it's angle grinder time but it should be noted that working in shops only once did we ever have to resort to this and it was on a crank that'd been on the axle for 25 years and the bike spent most of its life left outside. Heck even last night I got four cotter pins that'd been on a bike for around 50 years with an hour and a half, a hammer and some patience.
When you use an angle grinder it's as much the amount of heat as the cutting that shifts it so have a couple of whacks with the hammer in the breaks between cutting.
Posted : 30/07/2015 12:48 pm
Choices are:
Suck up embarrassment and go to LBS
Buy cheap angle grinder
Drive over to mine and I'll angle grind it off for you and attempt to embarrass you further
Edit : or one of those pullers pictured above - bit less brutal
Am I doing this right? 2 kettles of hot water and the crank is too hot to touch yet nothing:
[url= https://farm1.staticflickr.com/255/20146068101_bd817780e1_z.jp g" target="_blank">https://farm1.staticflickr.com/255/20146068101_bd817780e1_z.jp g"/> [/img][/url][url= https://flic.kr/p/wGeSaK ]image[/url]
Of course I am rotating the crank and hitting it in different places
Posted : 30/07/2015 12:59 pm
If you don't fancy the angle grinder, you can just drill a series of holes into the crank and then ride it a bit.
Posted : 30/07/2015 1:04 pm
I dont have the tools.
At the point, the whole frame is going in the bin TBH
Chill
...and take it to your LBS.
[[i]Steven Berkoff[/i]] There is no shame...[/[i]Steven Berkoff[/i]]
Posted : 30/07/2015 1:07 pm
That's essentially right, though your chisel is a touch weeny for the job. We used to have something which looked like a chisel but much bigger that we called a battering tool and I thought was called a battock but I can't for the life of me find what it's really called.
Are you using a lump hammer? If not do.
As for the LBS, they will do essentially what you're doing before angle grinding it if it really is so bad. For the cost I would buy an angle grinder yourself.
Next time grease the shit out of your extraction tool and really push it home.
Just go with the angle grinder option now Kryton,you look like an angle grinder kinda guy.
If by some minor miracle you buy,borrow or steal a puller,don't forget to put a jubilee clip round the legs. 🙂
Posted : 30/07/2015 1:08 pm
Surely someone could lend you a drill? Or just buy a hand drill from somewhere cheap - it'll do the job for what you want.
Posted : 30/07/2015 1:09 pm
ok look, homebase is a mile up the road.
The angle grinder option - where/what do I grind? The out surface down the the BB taper on the non drive side for sure, but what about the drive side? I won't get it between the rings and the BB shell...?
Posted : 30/07/2015 1:12 pm
Take the rings off first.
Posted : 30/07/2015 1:13 pm
You should be able to remove your rings in situ.
Edit : Gah, beaten
Posted : 30/07/2015 1:14 pm
Teasel ,he should just bring it round to yours. 😉
Posted : 30/07/2015 1:16 pm
To be fair, [s]we're[/s] I'm not that close...
Posted : 30/07/2015 1:18 pm
Ok rings are off. Just cut off a spider are and then grind down to flat?
Posted : 30/07/2015 1:21 pm
What Angle Grinder to remove cranks ? 😀 😉
Posted : 30/07/2015 1:22 pm
Ah well,the grinder will bring out the [s]bodger[/s] [s]sculptor[/s] artist in him 🙂
Posted : 30/07/2015 1:23 pm
I can't believe you hadn't already taken the rings off while attacking it with a hammer/chisel/etc 😆
Posted : 30/07/2015 1:25 pm
What did I tell you?
Get the proper tool (like Shand's link, or the Stein tap & tool, which some LBS have) or an angle grinder.
Hammer/chisel is an awful thing to put to a bike. Taken much pain of the bb shell yet?
Posted : 30/07/2015 1:29 pm
The next 10 minutes will be crucial .
As long as he avoids any grinder/frame interface it will be fine.
Or,it's all back to ..
[b]What CX bike with disks and a full mudguard option?[/b] 🙂
Posted : 30/07/2015 1:30 pm
Could be what sunglasses for Heritage car brand driver. Can't wait.
Posted : 30/07/2015 1:51 pm
Well, thats the non drive side and 2 spider arms off.
God, it takes a long time, and I supposed to be using the edge or the flat of the grinder?
Posted : 30/07/2015 2:45 pm
The edge
Edge into the top of the axle hole.
Posted : 30/07/2015 2:46 pm
Assuming it's a cutting disk then the edge. Should go through a crank arm like it's cheese. Make sure there's nothing too flammable in the line of fire of the sparks.
Was just looking for a picture. Found a few unpleasant ones... be careful with it!
Posted : 30/07/2015 2:47 pm
munrobiker - Member
oh, so effectively cutting the crankbolt hole in half? Ah, I was grinding the whole "outside" back to the BB
Posted : 30/07/2015 2:49 pm
^^^ that deserves a 🙄
and
a
Posted : 30/07/2015 2:51 pm
I'd just cut the crank arm close to the axle on two sides so you can lever it apart and off the axle.
The steel axle's going to be a lot harder to cut.
Posted : 30/07/2015 2:54 pm
Kryton- not quite, I mean here, from the top of the bike, not the side.
[img] https://lh3.googleusercontent.com/CO9zdsGmuYKdU1ThxB-P-rohuyKgjLvAcqcwAO07xylt=w295-h220-no [/img]
Once you're through to the axle the hole will open up and it should come off. No point cutting into the axle as it's much, much harder.
Posted : 30/07/2015 2:56 pm
Ah well, new frame time.
The bit on the spider the arrow above points to is conical - narrow end in. Cant get the grinder near it, crank now a pile of crap attached to a frame - which I just slipped and took a chunk out of the chain stay.
Recommendations for frame and fork? 😥
Posted : 30/07/2015 3:24 pm
Oh god.
Posted : 30/07/2015 3:25 pm
Oh, phew, you did a stealth edit. I came in, saw this -
And assumed you'd chopped your downtube.
Alternatively go into it like this, cheaper than a new frame-
Posted : 30/07/2015 3:31 pm
 Yak
wtf? Just looked at all this and kryton has slipped with an angle grinder and gone into the chain stays!?
yikes! just a scuff I hope. 😯
Posted : 30/07/2015 3:37 pm
Still got yer fingers then ?
Good.
Frames are cheap compared to fingers and much easier to get hold of.
Heres a link you might find useful...
[url= http://singletrackworld.com/forum/topic/what-cx-bike-with-a-full-mudguard-option ]I recommend you open this link[/url]
Posted : 30/07/2015 3:38 pm
Oh shit,sorry to hear that Kryton,I thought you were on a roll with your new grinder skilz.
I now feel bad for putting the hex on you with that 'grinder/frame interface post' earlier. 🙁
Posted : 30/07/2015 3:40 pm
I'm embarassesed to post this, but for the sake of any help, the mess:
see the nicks in the frame?
[url= https://farm4.staticflickr.com/3794/19521222704_e5cf1c02e1_z.jp g" target="_blank">https://farm4.staticflickr.com/3794/19521222704_e5cf1c02e1_z.jp g"/> [/img][/url][url= https://flic.kr/p/vK2npf ]image[/url]
Posted : 30/07/2015 3:42 pm
Giant Defy?
Just a thought, if you can't shift it & don't want a trip to the LBS why not try your local back street garage? They'll probably have a puller that will do the job or just smack it off.
If you're coming down this way I'll happily have a go.
Edit: looks salvageable.
So I reckon thats a ribble / planet x frame for winter thats cost me.
Doesn't look that bad.
Posted : 30/07/2015 3:45 pm
 Yak
Might get away with those nicks if they are chain-suck sort of deep.
Posted : 30/07/2015 3:46 pm
is it a sticker?
That'll be fine I reckon. I'd ride it. Just keep an eye on it. If you're really worried, get a carbon fibre kit and wrap it.
Or duct tape 🙂
Posted : 30/07/2015 3:47 pm
awww shit!! this thread seems to be coming to an abrupt end due to Kryton's cack-handedness with an angle grinder!
i was hoping it would have had the longevity of his Phall munching escapade! 😉
you should have continued bashing it off with a hammer...15 minutes? you werent even getting warmed up!!
But how do i get the crank off?
Here's e backup, seeing as I was going to go 105 and splash 850 on a tcx any way....
http://www.pedalon.co.uk/acatalog/giant-defy-1-2015.html
Posted : 30/07/2015 3:49 pm
Get a drill! Surely it's a useful tool to have around the house anyway?
Posted : 30/07/2015 3:50 pm
I've got a drill. What do I do with it? I do t have a bit big enough to drill out the spindle.
Posted : 30/07/2015 3:51 pm
No, you just drill a series of holes into the crank (the part at the top of your pic) in a line(ish) so that there's hardly any metal holding it together. Then hit it or ride it a bit and it'll break/split and fall off.
4 or 5mm drill bit I reckon. Alu is soft so it won't take long to drill a few holes.
Posted : 30/07/2015 3:52 pm
Seriously though, if you can secure (what's left of) the crank arm in a vice or something then use your chisel to **** the end of the axle with your biggest hammer I reckon it'll go - you just need to have someone/thing to hold or catch the frame when it does.
put somethign behind the crank arm so you can't cut the frame and carry on cutting.
if you held the blade parrellel to the ground as it is in that shot and cut into the arm just above the spindle you'd get through without hitting the frame.
Posted : 30/07/2015 3:53 pm
good lord....
I think i will turn down your kind offer of the angle grinder kryton..;-)
Posted : 30/07/2015 4:27 pm
Does anyone else feel this thread is rapidly becoming worthy of inclusion on the 100th edition cover?
Posted : 30/07/2015 4:31 pm
Tpbiker I suspect the problem isn't so much the tools...
Posted : 30/07/2015 4:36 pm
Hoo-****ing-ray...
[url= https://farm1.staticflickr.com/279/19957169120_0672cb0548_z.jp g" target="_blank">https://farm1.staticflickr.com/279/19957169120_0672cb0548_z.jp g"/> [/img][/url][url= https://flic.kr/p/wpxH5L ]image[/url]
Now, will my paranoia let me do a 100k without worrying about the frame snapping...
Posted : 30/07/2015 4:43 pm
Bike upside down?
Oh dear.
EDIT just seen that Kryton trashed his frame then carried on. I almost feeling like retracting my comments above.
Posted : 30/07/2015 4:44 pm
You don't have the BB out yet.....
Posted : 30/07/2015 4:45 pm
Filthy Bike...
Filthy Boy...
At least you have your fingers left, you do don't you?
That frames fine, just keep an eye on it and cover the marks in black paint..
You
Are
a
One
Aren't you. 😀
Posted : 30/07/2015 4:50 pm
anono - Member
Yes. Most definitely!
Posted : 30/07/2015 4:56 pm
If anyone ever asks again why we need LBSs ,show them this thread.
Don't worry about the marks Kryton,no one cares about their winter bike 😉
Posted : 30/07/2015 5:00 pm
