Recommend me a tyre...
[Closed] Recommend me a tyre to try going tubeless with.
[#5723861]
I have a set of 26" Ztr flows, I mostly ride in the North downs or at the moment mostly as a road commuter apart from 600m of clay based mud.
I need a new front tire and I want to try tubeless so I want something that will make it as painless as possible.
I have a collection of valves, rim strips, yellow tape and sealant.
What is your recommendation for something that fits and grips?
Posted : 26/11/2013 3:05 pm
Mud X-good all-rounder & rolls pretty well-easy to inflate tubeless but you may need a compressor.
Posted : 26/11/2013 3:08 pm
Oh should have said no compressor but some co2 cartridges if the track pump fails.
Posted : 26/11/2013 3:10 pm
Spesh storm control or purgatory. Go up with a track pump on Stans easily
Posted : 26/11/2013 3:11 pm
My Chunky Monkey is excellent tubeless, went straight up and it has side wall protection built in.
Posted : 26/11/2013 3:18 pm
Those 2 surfaces, mud and winter clay, are polar opposites. Th Mud X is a great mud tyre, but will be very draggy on the road.
Try an On-One smorgasbord - very cheap, good all rounder and works well tubeless.
Posted : 26/11/2013 3:33 pm
This.
Or I've always found Continental Barons to up like a dream, and they're ideal for riding in the british winter months.
Posted : 26/11/2013 5:04 pm
I have Maxxis Ardent 2.4 on the front on ZTR Flows and 2.2 on rear.
Posted : 26/11/2013 5:06 pm
Oops my earlier post should have read "road" and winter clay.
Posted : 26/11/2013 7:06 pm
on one smorgasbord? wouldnt use one of them personally speaking from experience
Posted : 26/11/2013 7:37 pm
Ran mine tubeless in the Alps with no issues, and now running it as a winter rear.
Is that photo with TLR rims, or ghetto?
Posted : 26/11/2013 7:40 pm
they are stans flows with correct rim strip and sealant, which ended up on my back...
Posted : 26/11/2013 7:41 pm
the chunky monkey has remained on the front though, which is good ๐Ÿ˜€
Posted : 26/11/2013 7:43 pm
Interesting. Sounds like an unseated bead. I don't think it's a regular issue, as loads of people on here run them tubeless, and I haven't heard it before.
Posted : 26/11/2013 7:45 pm
Smorgasbord blew off my 26" flow rim on its first outing. That said, very happy with the tyre now that a tube is fitted.
Posted : 26/11/2013 7:52 pm
the tyre itself was slacker than a wizards sleeve on the rim, took no putting on or removing. seated it with a tube then put plenty psi in to make sure rim was seated. It had around 30 psi in it when it blew off and made a canny bang!
Posted : 26/11/2013 7:54 pm
๐Ÿ˜ฏ ouch!! Maybe it doesn't like flows! Mine has been on an 819 and a crossride
Posted : 26/11/2013 8:40 pm
well I went for a specialized purgatory as I could pick it up on the way home.
Turned out to be a piece of p*** to fit and inflate once I took the inner out of the valve, now just leaving to see if it stays up all night.
Thanks for all the recommendations, I was thinking of giving the smorgasbord for the rear but not now ๐Ÿ™‚ .
Posted : 26/11/2013 11:52 pm
To be fair, tubeless can pop for a number of reasons. My ardent went on the rear at Gawton. I'd battered it all morning and it was fine, then an innocuous roller after lunch popped it with a massive BANG. The rear was used and the front brand new when fitted. The front, also an ardent is still going strong.
Posted : 27/11/2013 12:05 am
Perhaps consider a Ground Control for the rear?
Posted : 27/11/2013 12:16 am
