Rebas... replacing ...
[Closed] Rebas... replacing pop loc with a dial?
[#7227350]
Complicated job? will the whole mechanism need replacing or just fit a knob? Thanks
Posted : 30/07/2015 11:22 am
you'll need to remove the return spring from the shaft too, otherwise you'll lock it out and it'll spring back to open.
Posted : 30/07/2015 11:50 am
[url= https://docs.google.com/file/d/0B1AoGIWBz4H1YWNhYWRkODYtNzRiNi00YTA1LTlmMjctNmQzOWQwMDdiZGFl/edit?pli=1&hl=en ]Guide here[/url]
Think it was a forum member who put it up I used it some time ago .
Posted : 30/07/2015 11:58 am
Bookmarked - Good guide link shredder!
Posted : 30/07/2015 12:27 pm
For bonus points you should take out the spring altogether, the (reverse threaded) top cap can be unthreaded from the plastic cartridge:
http://forums.mtbr.com/shocks-suspension/motion-control-rebuild-possible-334622.html#post3492191
Posted : 30/07/2015 12:34 pm
 P20
Pretty straight forward. I managed it!
Posted : 30/07/2015 3:04 pm
Splendid job, thanks shredder. I've just been down my lbs and he reckoned it'd need a new internal for £90 odd.
Posted : 30/07/2015 4:11 pm
the linked guide was written by PeterPoddy - I used it a few yrs back and found it very helpful
Posted : 30/07/2015 5:01 pm
It should take you all of ten minutes. I've done it twice.
Its worth doing the extra step of removing the spring by unscrewing the top of the plastic cartridge
Posted : 30/07/2015 5:25 pm
Yep very easy job to do. Note the spring is quite stiff so take a bit of effort to get it off. At first I was being a pansy and couldn't shift it, eventually thought f** it and just went for it and it came out nice and easy. No damage to the damper and its still running fine years later.
Posted : 30/07/2015 5:32 pm
That'll be me wot did it. 🙂
Newer forks are a bit different but the theory is the same (Those were 2004 models if I recall correctly) and the newest ones (last couple of years) can't all be done without changing the damping cartridge I think
Posted : 30/07/2015 6:03 pm
