[url= https://www.amazon.co.uk/Vaude-Road-attach-Bicycle-black/dp/B004L4EIC2/ ]amazon link[/url]
£75 down to £15, Seems like a decent price unless I’m missing something.
Vaude make good kit
Hmmm, that might just make a good commuter bag instead of my current (perfectly good) drybag...
Can you get spare seat post mountings cheapish?
Spare mounts are readily available for a few quid.
Only thing is, it's not crystal clear which one this bag uses. The pictures appear to show a Contour Max bracket, but one of the reviewers says it comes with a different mount to the picture, which could be the standard Contour.
I have the standard Contour on several bikes so I'm off to do some research…
Edit: mm, looks like it's the Max; maybe the reviewer got sent the wrong item.
https://www.vaude.com/en-GB/detail/index/sArticle/6133/number/125930000
Perfect for my winter commuter. Cheers for that.
Bloody hell, I've got one of them it's great if you travel light.
I'm tempted to get another even though I don't need one, the carradice is great, but half empty most of the time and weighs a ton.
Thanks to Amazon's recent "buy gift cards and get free money" offers it cost me £3 😀
Cheers , Bought, another PSA to go in the cupboard 🙂 Always seems to be on a Friday morning when in work fed up and a bit of retail therapy is needed and the weekend can`t come quick enough!!
Cheers OP Bought this
Also just bought - will be useful for trips on the fixie where I don't want a backpak... Reckon an ipad will fit in it?
DrP
Bought one this morning, Free prime delivery so it's silly not too really.
oddly enough the price had gone down by 30p since last night, is it going to be under a tenner by tonight?
Pretty much my expected use, I'm going to ttake the beam rack off my commuter and just have the "klick fix" adapter on the post, should be neater, might put one on the Grrrravel bike too.
Oof, I've just seen that the Max brackets are a lot more expensive than the standard ones…
No chance getting a full size ipad in DrP, Maybe a mini, but even then I think it would be a struggle. They're (the bag) an odd shape, not quite square.
I used to fit in, lunchbox, 2 apples, a banana, rolled shirt, boxers and socks plus 2 inner tubes and a multitool. It was pretty much full then, if I had a waterproof jacket I had to strap it to the top.
Yep iPad fits in this fine, even without the zip to expand it. Also confirmed it’s the max adapter.
mine arrived today - cheers OP bigger than I expected and pretty substantial - shame the additional brackets will cost more than the entire pack cost!!!
Junk yard... Yeah, thinking about it i should have ordered 2 packs.. 🙄 !!
DrP
Still about the same price which is just nuts
Cannot see an easy way of making one either - thankfully all my posts are the same size so that is my fix
It's up to £30 now...!!
I'm just soaking my fixie seatpost in wd40 before getting the blowtorch out... First time in 9 years I've had to remove the post.. Guess what's the issue...!!
However, it's a great little bag.. Will be tidy on the commuter for trips to town/meetings.. And as said, iPad fits in on its side no issue 🙂
DrPp
Used mine this morning - It's a bit rattly, but has improved my roadrat no end (pannier rack and bag on one side + roadrat frame = noddle bike!).
You really need to tighten the clamp up, otherwise it rotates easily.
Fits all I need in it without being expanded, so have room for extras if/when required.
Awesome for £14.10. 😀
Also I think the frame would double up for bikepacking duty nicely if you strapped a dry bag to it.
Missed delivery yesterday, no attempt to drop it today, hope it comes tomorrow.
Doddle to your local Morrisons!, off to pick mine up now
Finally delivered it yesterday, on their second attempt, it's absolutely brilliant for £14!
unfortunately the cheapest I can find a second mount is £20, and I really want a second mount now.
I wish I had ordered two...
What's the likelihood of them being knocked down again for black Friday...
Swap seatpost and saddle between bikes (although not all will be 27.2 in my case).
I like my Topeak MTX beam rack, but that Vaude really is a bargain.
Price up to £52 now.
I bought one of these and it arrived today. It seems ace, so I’ll save it for if I ever get a job within cycling commuting distance from home.
