poxy tubeless tyre!...
[Closed] poxy tubeless tyre!!!
 jedi
[#3535091]
arrgghhhh the tyre burped again and the casing has a kink in it, well ripples actually so it looks buckled. damn continental rubber queens. great tyre when it stays put 🙁
Posted : 06/01/2012 7:42 pm
 jedi
[url= http://farm8.staticflickr.com/7144/6648383971_acf2ddb4fb_b.jp g" target="_blank">http://farm8.staticflickr.com/7144/6648383971_acf2ddb4fb_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/ukbikeskills/6648383971/ ]IMG-20120106-00092[/url] by [url= http://www.flickr.com/people/ukbikeskills/ ]ukbikeskills[/url], on Flickr
Posted : 06/01/2012 7:54 pm
Workman/tools etc *whistles*
Posted : 06/01/2012 7:55 pm
 jedi
oh do explain?
Posted : 06/01/2012 8:04 pm
Never seen that happen before? Tyre defect? Shouldn't ripple like that.
Posted : 06/01/2012 8:31 pm
 jedi
its doing my head in. i love the way tubeless rides/feels but i cant have them blow like that 🙁
going to try schwable
Posted : 06/01/2012 8:35 pm
Assuming it is in the bead correctly I would say that the tyre is a duffer.
Posted : 06/01/2012 8:50 pm
stick a set of minions on instead, mmmmm grippy
Posted : 06/01/2012 8:51 pm
 jedi
i had minions but they wouldnt seal 🙁
Posted : 06/01/2012 8:57 pm
really? I just got a set and they went more or less straight on. thats from brand new though, Ive had the devils own job getting old maxxis to seal when I've swapped them between wheels
that rippling is strange though, I've burped tyres after stupid clumsy landings but never made them look like that
Posted : 06/01/2012 9:00 pm
i guess that damage is the result of multiple blow offs and that tyre is for the bin
bit concerned if you couldnt get minions to seal, were they ust? mine were tight as a gnats wotsit when new, going on 819s
no dink in the rim is there?
tubeless convert - various maxxis and bontys on 819s & 823s
Posted : 06/01/2012 9:01 pm
Maxxis UST and non UST (dual ply) seal fine, certainly on Mavic UST rims... You just need a lot of soapy water and some sealant for the non UST version.
Get it warrantied? Not 100% sure on contis policy on tires used with sealant.
You could try Bonti Super Juice? A little less aggressive than stans.
Posted : 06/01/2012 9:27 pm
 jedi
soobalias, no dings . i tried non ust minions
Posted : 06/01/2012 9:48 pm
 jedi
too it off and tried it on the front. its deffo the tyre 🙁
anyone else had this happen?
Posted : 07/01/2012 10:04 pm
Go back to the Minnions and before you fit them go round the bead and edge close to the bead and snip off all the releasing nipples from the edge with a very sharp knife or decent scissors. This solved all my ghetto tubeless bead sealing problems-they sealed pretty well then with no sealant in!
Managed to burp them twice once head on into a stump and once on a side wall landing on a drop off on to a rock at Dalbeattie.
Posted : 07/01/2012 10:28 pm
 jedi
i got tubeless rims and want tubeless tyres as i love the feel. will try scwable
Posted : 07/01/2012 10:42 pm
Inner casing separated from outer casing?
What sealant you using, Jedi? I had a problem with Joes in a Bonty TLR tyre which degraded the inner casing and caused separation which resulted in a loud blowout (possibly due to high ammonia content?)
[url= http://farm4.staticflickr.com/3453/3782022752_d975a29bcc.jp g" target="_blank">http://farm4.staticflickr.com/3453/3782022752_d975a29bcc.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/stuartie_c/3782022752/ ]Age[/url] by [url= http://www.flickr.com/people/stuartie_c/ ]stuartie_c[/url], on Flickr
Though, to be fair, it was quite an old tyre!
Posted : 07/01/2012 10:43 pm
 jedi
brand new ust rubber queens with stans (tiny bit)
Posted : 07/01/2012 10:49 pm
Whack a toob in there?
Posted : 07/01/2012 10:56 pm
 jedi
it wont stop the mishape and the tyre blowing off
Posted : 07/01/2012 11:08 pm
 jedi
tyre gave up the ghost today as it snaked all over the rim and is unusable 🙁
Posted : 08/01/2012 9:08 pm
Just fitted some Spesh Eskar 2 Bliss on my Mavic 321s with a Stans kit, tyres have been used quite a bit but got both of them on and sealed pretty quickly. Not ridden them in anger yet though.
Posted : 08/01/2012 9:27 pm
Watching the tyre try and twist off the rim as Jedi lands a massive hip is pretty scary!
Posted : 08/01/2012 9:50 pm
 jedi
it feels like playing russian roulette 🙂 🙂
Posted : 08/01/2012 9:52 pm
OK, I take it all back. I ripped my rear minion clear off the rim today coming off rushup edge in the peaks. It wasn't even one of my trademark clumsy landings.
maybe I was a bit ambitious choosing a folding minion.
Posted : 08/01/2012 10:32 pm
bike i rode today has tubes
spent quite a while holding my breath and thinking light thoughts going past huge amounts of recently trimmed hawthorn...
Posted : 08/01/2012 10:38 pm
 jedi
i put a minion with a tube on the back and it felt like a block of wood 🙁
Posted : 08/01/2012 10:50 pm
I had that happen enough times myself. I then had a bunch of people tell me I needed to use specific tyres. I don't see the point of forcing myself to use tyres I don't like just so I can run tubeless. Mental. Back to tubes.
Posted : 08/01/2012 10:51 pm
My problem with tubeless is the one time you REALLY want a tyre to hook up and land properly without rolling off the rim is when you're landing a drop, or screwing one up. That's the last time you want the seal to burst and the front end to wipe out.
Posted : 09/01/2012 2:43 am
 jedi
i love the way tubeless feels on the bike so i will try another brand.
i even took the tyre off and reseated it yesterday and carried on. when the tyre snaked on the rim again i was about to take off of a laddder drop and glad i felt it 🙁
Posted : 09/01/2012 9:30 am
Do any pro freeriders use tubeless? As a wheels much closer to the ground rider I love tubeless but I'm convinced that some brands are much better at making reliable tubeless ready (but non-UST) tyres than others. On that basis I'd look at the Bontrager XR4 or Specialized Purgatory if you want something similar to a Rubber Queen that tubelesses well. But I'd also check if any other lunatics riding like you have had success going tubeless! 😉
Posted : 09/01/2012 9:43 am
Good luck, Jedi. Schwable tyres have been good for sealing in my experience.
I spent yesterday trying to get a new-ish (but used) Advantage to seal - converting to tubeless. Would the beads go anywhere near the edge? Not a chance. So it looks like try a new tyre (expensive) or carry on with tubes (thorns!!).
Posted : 09/01/2012 9:51 am
I'm going to press on with tubeless even after violently taking one off the rim. I pinched the inner tube I put in with 5 miles yesterday and had to mince down one of the best descents in the peaks worrying about pinching my last tube. I cant go back to doing that
Posted : 09/01/2012 11:26 am
Since going tubeless, I've only ever had one tyre burp off the rim, that was a schwalbe, not that it matters as I suspect I just hadn't seated it properly. In my experience Maxxis UST seal best, they seem to go on easily and stay on, in all conditions. I've used Maxxis tyres with proper UST rims and Stans, no probs. I've tried most other brands and always struggled to get the fekkers on the rim.
Posted : 09/01/2012 11:31 am
Gee atherton didn't seem to have too much luck this year with his...[url= http://lp1.pinkbike.org/p4pb6810177/p4pb6810177.jp g" target="_blank">http://lp1.pinkbike.org/p4pb6810177/p4pb6810177.jp g"/> [/url]
Posted : 09/01/2012 8:08 pm
Saint rims - there's the problem. He should have used Flows or 729s EVERYBODY know that 🙄
Posted : 09/01/2012 8:15 pm
 GEDA
I was doing 180s (The only trick I can do) in the park showing off to my children and it turned into a embarrassing dad moment when the tyre burped , exploded and I fell flat on my face. Would never quite trust tubeless after that.
Posted : 09/01/2012 8:17 pm
 jedi
i got some hans dampf's schwable tyres today. will see 🙂
Posted : 09/01/2012 9:07 pm
How are the Hans Dampf's working out? Tempted by a set. It's between them and another set of Advantages...
Posted : 13/01/2012 7:33 pm
 jedi
3 rides in and they feel great
Posted : 13/01/2012 7:36 pm
