One for the people ...
[Closed] One for the people "in the trade"
 juan
[#695094]
What is XC?
If I buy a XC bike what will void the warranty? IS a on-one/ragley more fragile than a cotic? Am i ok to jump with a cove hj or a chormag or a kona as probably XC in BC is different than XC in UK?
The thread about the HJ got me thinking. I would define my use of the bike as XC but it is actually what bike manufacturers call XC?
If I want to hop of a kerb/step will I have to buy a Free ride bike?
Any info would be useful
Posted : 09/07/2009 9:35 am
I don't even know what XC is.
I know what "XC Race" is. I know what "Trail" is.
I know what "Endurance Race" is.
[url= http://www.ragleybikes.com/2009/07/how-strong-is-the-blue-pig-frame/ ]How strong is the Blue Pig?[/url]
Posted : 09/07/2009 9:38 am
 juan
Well not talking about race, just talking about riding the bike. More precise example, will you warranty one of your frame if you knew the rider was not pushing down steps or had the wheels off the grounds (no more than 1.5-2.00 m though).
Will you consider that being Free ride or will it be just normal riding?
Posted : 09/07/2009 9:50 am
Judging by the pics of you doing those drops I would say that you do general trail riding. Some people might say thats AM but its definitely not freeride and as more than one wheel is leaving the ground at a time I would say its not xc.
To me xc would be used to describe the kind of riding a beginner would do as they dont have the skills to manage the tougher stuff.XC Race is skinny whippets with no body hair banging elbows. XC is wheels on the ground distance riding. Trail is the same but with wheels off the ground (at times). God knows what AM really is but I guess its when you use the same bike for a trail ride and a DH track. Freeriding is crazy. DH is DH.
HTH 😀
Posted : 09/07/2009 10:06 am
I have to disagree I_Ache ( suprise suprise 🙂 ) - xc can and does involve both wheels off the ground - even for someone as unskilled as me. Bunnyhopping water bars for example or going odd small drops. I would say jumps less than 1m high
Posted : 09/07/2009 10:09 am
Our frames are warrantied for manufacturing defects. It doesn't matter what the rider is doing on it.
Posted : 09/07/2009 10:10 am
For real???
Posted : 09/07/2009 10:14 am
Bikes aren't as fragile as you think Juan. Sure if you're 18st and ride like a 3-legged drunken donkey then you need stronger kit than a 10st skilled XCer but people get WAY too hung up on XC/AM/FR etc.
Chances are if you stuff any bike into a tree at speed, you'll bend it (the bike, not the tree...) and, as Brant said, it won't be warranty.
Posted : 09/07/2009 10:15 am
 juan
I know crazy legs 😉 Trajectory errors are not warrantied 😉
What i mean is if a XC frame was to bend/crack as the results of going down one of those steps, would I be right to ask for a warranty?
Or in other hands am I going to die if I keep doing all that?
Posted : 09/07/2009 10:19 am
 juan
I_hache thanks, i would say AM is trail riding just steeper 😉
Posted : 09/07/2009 10:20 am
 Olly
tricky one, i think its down to the manafacturers discretion as to how or why a frame broke.
if its a shoddy weld (which can happen in any production line) then it SHOULD be fairly obvious.
ive only ridden factory welded allux frames, so they are as strong as a strong thing, and i would be suprised if i managed to break one in any way! but if the head tube has been ripped off a 21" whippet frame, clearly from landing heavily, then i think it would be pretty obvious from looking at it that it had been mistreated.
Posted : 09/07/2009 10:23 am
[i]or had the wheels off the grounds (no more than 1.5-2.00 m though).[/i]
If you're getting the bike 2 meters in the air, I'd suggest your riding is pretty far removed from what most people - especially manufacturers - would consider XC.
Posted : 09/07/2009 10:24 am
Have you seen the abuse bikes can take?!
Watch Paris Roubaix for example, a lot of people on here would struggle to ride their 5.75" adjustable travel/geometry all mountain bike over some of that stuff yet there are road bikes screaming over it at average speeds of nearly 30mph.
I've seen people ride cyclo cross bikes down stuff that some people wouldn't ride on a normal FS - watch the Three Peaks CX race and tell me that isn't "all mountain" yet it's done on skinny tyred drop barred bikes.
Just ride. Seriously. So long as you have some vague modicum of skill, the bike will survive anything you can ride it down. It may not like being dropped off a car roof rack onto a motorway at 70mph but that's totally different forces it's not designed to withstand.
Posted : 09/07/2009 10:25 am
[i]It may not like being dropped off a car roof rack onto a motorway at 70mph but that's totally different forces it's not designed to withstand.[/i]
If it helps, I can verify that the Dialled Bikes PA frames can handle this no problem!
Posted : 09/07/2009 10:29 am
 juan
Dance the I will not die happy dance.
Posted : 09/07/2009 10:36 am
TJ If thats the only thing you disagree with me on then I shall consider my post a success. 😀
I will conceed that point but say that 1m is a bit high for a normal XC ride I would say 50cm absolute tops.
Posted : 09/07/2009 11:00 am
 Olly
i put 105mm forks on my XtC (designed around 80mm) which slackened it off a smidgen, shortneed the stem, and i considered it a trail bike.
muhah
Ive also run it into a van at 45mph, and flipped over the bonnet/bars, got money for a new frame and fork, and still ride the old one "like i stole it"
its fine 😀
mech that was on it has some epic tarmac scars though 😀
height isnt really a discerning factor on load on the bike, only on how scary it is!
a drop off a big kerb (up to a foot) will land a harder hit on the bike than a properly excecuted 5ft drop onto a steep smooth downslope of course.
Posted : 09/07/2009 11:04 am
 juan
I do know that, question is about weather or not the bike is meant to be thrown on the 5 foot drop...
Posted : 09/07/2009 1:26 pm
 GW
common sense at all?
buy a frame built of a suitable material to a strength and weight bracket for your riding style and weight.. end of!
plenty elite level DHers race a bit of XC/enduro etc. too, do you think they mince down the descents? christ, I started DH racing on an XC race hardtail. if the landing transition is good and you're reasonably smooth even a lightweight XC race bike will cope with a 5' drop.
Posted : 09/07/2009 1:40 pm
It's usually about now that Oli_y posts a pic of him coming down Caddon Bank on his plastic bike.
Posted : 09/07/2009 1:45 pm
