niche amalgamation ...
[Closed] niche amalgamation question - 29ers on fat frame ?
[#3242296]
just thinking, like: fatbikes are 26 inch wheels plus massive tyres so a normal to biggish tyre on 29er wheel should fit fine, should it ?
Rear hub is what, not 135 I assume
BB shell ?
What else is abnormal ? (front 135 ?)
Posted : 13/10/2011 6:45 pm
If its a 135mm rear the dishing will be different.
some fatbikes have 170mm rear hubs which would run a 29er rear with no probs.
I've run a rear 29er wheel in my fat bike fork.
Posted : 13/10/2011 7:01 pm
170 rear ? 😯
I'd expected 150 or 143.7683 (or whatever that new one is)
Posted : 13/10/2011 7:09 pm
135 or 170 depending on which frame you choose. The new On One is 170 apparently.
Posted : 13/10/2011 7:11 pm
Cheers. OK, are the 135s so weirdly dished that it'd be a new wheel anyway (if so, I appear to be out, unless std hubs can be spaced to 170 somehow)
what's the BB like - can't possibly be standard and takes "normal" cranksets, can it ?
(Oh I know it'll all be on google, but this is nearly useful to others too)
Posted : 13/10/2011 7:22 pm
Typically 100mm BB, choice of Square, ISIS or buy new external BB cranks.
Wheels would prob need rebiult with new spokes i imagine.
Depends what frame its for...
Posted : 13/10/2011 7:59 pm
[url= http://forums.mtbr.com/fat-bikes/ ]All the info you need[/url]
There's no hard and fast standards for fatbikes but [b]most[/b] have 100mm BB's, 135mm front spacing and either 135mm offset rear or 170mm none offset rear spacing.
I'd imagine that it'd be quite difficult to build a 135mm with enough offset on a standard 29er rim.
If you look at the spoke holes you can see how offset the rim is on a 135mm rear end.
[img] ?w=263&h=480[/img]
Posted : 13/10/2011 8:04 pm
Look up Mikesee's custom moots thread on MTBR. He did the 29/fat convertabike a while ago, in style too.
Posted : 13/10/2011 8:17 pm
The offset is only 6mm I think. There is one offset 29er rim by velocity, I think a UK fat biker has done it-Jonny someone?
I looked into it myself ap it does seem to make sense to double up...
Posted : 13/10/2011 8:41 pm
