Have we had this yet?
[url= https://comingsoon-tech.com/moar-ebikes-ultimate-full-suspension-fat-bike/ ]Apparently it's the ultimate bike[/url]
I particularly like the picture of it on the beach with it set up with the forks back to front.
If it get's stolen, do you give the postcode of the front end or the rear wheel?
'Built from the ground up'
I would dispute this. Normally I start with a frame. The wheels and tyres go on after quite a few components are added to the frame first.
If you teamed that with the Chinese army shovel thingy you'd be prepared for anything.
Except a powercut.If you teamed that with the Chinese army shovel thingy you'd be prepared for anything.
Or locusts. A shovel and a bike would be useless against locusts
Hub motor - so not good at low speed. Surely the ultimate e bike has a bosch central motor. Much better in many ways
I take issue with that 😉
All depends on the motor system - hub motors can give a lot of torque at low speed, without the worry of excessive torque through the chain and transmission.
The white one has a 'under the BB' motor. Must be different prototypes? the rest have some sort of bracket so I presume they're designed around that.
I think that's the very least of its faults 🙂
Adjustable handling characteristics.
I wonder whether the weight or the RRP will be the most comedic ally enormous figure.
You lot are all luddites, I tell ya,
This is the future.
Some mug will buy one. Can it be made anymore wronger?
