Maths question - wh...
[Closed] Maths question - what x such that 2^x = 10y where x,y are integers
[#1036850]
as per title really! anyone know?
Posted : 13/11/2009 2:04 pm
none
Posted : 13/11/2009 2:07 pm
10 = 2 * 5 and there are no integer multiples of 2 that make 5
Posted : 13/11/2009 2:08 pm
42?
Posted : 13/11/2009 2:12 pm
What simon said. 2^x is always going to end up finshing in 2,4,6 or 8, never 0
Posted : 13/11/2009 2:15 pm
not quite sure what SFB is getting at, but that equation cant be solved, you need the same number of equations as you have unknowns
eg
[u]if x=1 then[/u]
2=10y so
y=0.2
[u]if x=2 then[/u]
4=10y so
y= 0.4
[u]if x=3 then[/u]
8=10y so
y=0.8
and so on
Posted : 13/11/2009 2:17 pm
oops, missed the interger bit 😳
 cp
it's 2^5 not 2*5...
i don't know whether it can be done, as 2^x as mentioned, always ends in 2,4,6 or 8 doesn't it?
Posted : 13/11/2009 2:20 pm
It doesn't even work if x=0...
So nope, no integer solutions...
Don't worry thisisnotaspoon, I thought I had a working answer but had pressed the wrong minus button on windows calc 🙂
 cp
and likewise, you wouldn't be able to solve it without another equation, you'd need to go on trial and error.
Posted : 13/11/2009 2:21 pm
the question is asking for one or more solutions, not just one, but in fact there are none. If the 10 were replaced with 8 then there would be an infinite number of them starting at x = 3,4,5 ... and y = 1,2,4 ...
ie x > 2 and y = 2^(x-3)
As far as I can work out SoB is correct.
Posted : 13/11/2009 2:30 pm
it's 2^5 not 2*5...
I was talking about the 10 in 10y. 10 is 2*5, so any multiple of it will still have 5 as a factor, but no integer multiple of 2 will make 5 (which is prime) so there are no solutions. Actually saying all powers of 2 end in 2,4,6 or 8 amounts to the same thing, as all decimal numbers have to end in a digit and zero doesn't work because all numbers ending in zero are multiples of 5 (ignoring 0 which is not a finite power of 2)
Posted : 13/11/2009 2:32 pm
I'd question that, the process might be called analysis
divide through by 2 to get 2^(x-1) = 5y,
observe all the possible answers on the left only have 2 as factors and 5 is prime
end of
Posted : 13/11/2009 2:49 pm
Simon: Since when has 2^(x-1) = (2^x)/2 ?
Would an easier approach be to assume both x and x must be negative, and ask when is log10(2^x) = integer ?
Saying that, I got no integers out by the time Excel packed up at log (2^-1022)
Posted : 13/11/2009 3:49 pm
[i]Simon: Since when has 2^(x-1) = (2^x)/2 ?[/i]
Stick some values in and see what you come back with 🙂
Posted : 13/11/2009 4:06 pm
Since, ummm, always.
Assuming you meant "assume both x and [b]y[/b] must be negative" this makes no sense.
x is negative => 2^x is positive
y is negative => 10y is negative
Therefore, 2^x = 10y has no solution for negative x and y.
Posted : 13/11/2009 4:07 pm
Just graph it you'll soon see the solution then.
Posted : 13/11/2009 4:11 pm
😳 Things happen when the mind's on the real job!
Posted : 13/11/2009 4:13 pm
Now, if [i]imaginary[/i] values of x are permitted... 😉
Posted : 13/11/2009 4:17 pm
it's interesting to speculate if it held true before the concept of number, or of powers, was conceived...
no real power of 2 whether positive or negative will yield a negative result, and all the negative powers will give a non-integer value less than one. But IMO actually looking at what is happening is more productive than a fishing expedition...
Posted : 13/11/2009 5:05 pm
note that x^2 + y^2 = z^2 has an infinite number of integer solutions (right angle triangles) but no one has ever found one for x^n + y^n = z^n for n>2, and Fermat claimed to have an easy proof, though I believe it was only satisfactory reproved recently! Why not try that in Excel ??
Posted : 13/11/2009 6:22 pm
Hmmm... Fermat's Last Theorem... that should be easy, after all, I have a book around here that tells me how to do it...
What could be so difficult?
Posted : 13/11/2009 6:32 pm
 GJP
I would say that Ian Munro has given the most sensible and intuitive answer so far. Any one who can multiple a number by 2 and get the correct result will see the recurring pattern that he is referring to within 30 seconds. Or at least this is true for positive values of x.
Posted : 13/11/2009 8:19 pm
I can't find the post this refers to 🙁
Posted : 14/11/2009 7:31 pm
