Light question. Sma...
[Closed] Light question. Small, like a joystick but with a tight beam. Ideas?
[#3159279]
I'm looking for a light ideally self contained. Joystick or slightly bigger but not much more. Must have a tight beam pattern out to 50/60 yds. The less spread the better. Anything off the shelf or a DIY job? I'm new to this lighting dealio. So any help appreciated.
Posted : 18/09/2011 3:58 pm
*Pulls up a chair*
Posted : 18/09/2011 4:14 pm
 Del
[url= http://www.cnqualitygoods.com/goods.php?id=1060 ]this one's[/url] been recommended as fitting the 'same size as joystick' criteria, but a tight beam out to 50-60 yards? that might be a bit subjective/impossible!
edit: would defo be interested to hear how owners get on with them.
biccy?
Posted : 18/09/2011 4:20 pm
I've got one of those Yezl XMLs winging its way from China to me. My neighbour's got a Joystick so I can do some beamshot comparisons, although his Joystik is a couple of years old now so not latest generation.
Posted : 18/09/2011 4:32 pm
Cheers for link. Can be slightly bigger than that. Say 8" long max. Ideally with a remote cable switch compatibilty so the switch can be say 12" away.
Posted : 18/09/2011 4:52 pm
In fact size isn't as important as weight tbh. I don't mind if it's redbull can sized as long as doesn't way a ton. Or if it's a head unit and battery separate as long as cable can be of coiled type.
Posted : 18/09/2011 4:53 pm
http://www.4sevens.com/product_info.php?products_id=2655
Not cheap, and certainly not sure about a remote, but as bright as you could possibly want. About 1200 lmn.
Posted : 18/09/2011 8:38 pm
http://www.dealextreme.com/p/trustfire-r5-a3-cree-xp-e-r5-3-mode-230-lumen-memory-led-flashlight-1-aa-1-14500-39062
Cheap as chips, $18, very small, very bright, again probably not what you're looking for, but the neatest, most useful little torch I've used. More than bright enough as a bike light around lanes using a Twofish Lockblock.
Posted : 18/09/2011 8:44 pm
That maelstrom is a beast, but waay outta my budget 🙁
Posted : 18/09/2011 9:04 pm
[url= http://www.fenixtorch.co.uk/led_torches/fenix-ld20-r4.html ]Fenix[/url]?
Posted : 18/09/2011 10:09 pm
SKU Product Name Quantity Price Line Total Options
01025 Superfire Gun Mount Pressure Pad ADDON
- + $3.99 $3.99
05297 Glass Optics for Flashlights (28mm)
- + $1.90 $1.90
05955 26.5mm Aluminum Reflector Drop-in Module Set (without Emitter)
- + $2.76 $2.76
12000 Universal Nylon Mount for Flashlights and Lasers
- + $2.06 $2.06
16240 UltraFire WF-501B Cree R2-WC 250-Lumen LED Flashlight Black (1*18650/2*CR123A)
- + $12.70 $12.70
33912 AC/Car Lithium Battery Charger for 18650 (100V~240V/12~24V)
- + $8.39 $8.39
42153 ASUCELL Rechargeable Protected 3.7V 3000mAh Lithium 18650 Batteries (2-Pack)
- + $14.70 $14.70
00000 Registered Air Mail ##
Package Tracking Service. $0.01 $0.01
DIY Option, going for this lot.
Posted : 18/09/2011 11:39 pm
Wysiwyg, that's a pretty comprehensive shopping list. I'll check that out when I've got some time. Re: Maelstrom; pretty damned impressive, and I'd love one, but the lottery will have to cough up first.
Posted : 18/09/2011 11:52 pm
I've got the XPG version of the Yezl - it's very bright works well - I haven't done a back to back comparison with a joystick but I don't think it'll be far off
Posted : 19/09/2011 1:29 am
What sort of burn time dies the yezi give? Can you get decent mounts for it or have you modded something to suit
Posted : 19/09/2011 7:01 am
M6TTF... if your username is also your car reg number you don't live far from me (Or I've seen you driving round town a few times, anyway).
You're welcome to have a look at mine when it arrives. I'm hoping it'll fit in a Joystick helmet mount. Email me through profile if you're interested.
Posted : 19/09/2011 8:35 am
 Del
they do fit the joystick mount apparently - info gleaned from another thread on here.
Posted : 19/09/2011 9:09 am
 Del
and i just pulled the trigger on one too. chap at work has the current joystick ( well, last year's now, i guess ), so will compare.
Posted : 19/09/2011 10:06 am
Mine has left Hong Kong.
Posted : 19/09/2011 10:41 am
The Yezl is a perfect fit in a joystick mount - that's how I use mine and it works very well.
Posted : 19/09/2011 1:17 pm
 Del
received my yezl on monday - pretty quick delivery. excellent. it's the 5 mode one. low/med/high, slow, and 'eppy' flash modes.
about as bright as my triple XPG lumi conversion, but smaller spot compared to that. probably won't be able to compare to my mate's joystick for a while, as i've heard today that he's injured himself, unfortunately.
i'm very pleased with it. for the money it's stonking.
Posted : 28/09/2011 10:48 am
