iPhone handlebar mo...
[Closed] iPhone handlebar mounts - anyone using them ?
[#4260858]
Fancy having Strava on the handlebars for when I'm road training.
Any recommendations on a good mount?
Posted : 15/08/2012 10:17 am
FWIW, have the Topeak Ridecase mounts - one stem on road, handlebar on MtB. Been fine; can use the stem one to video rides, but not only would you be unable to see screen when riding, it would make the iPhone way more vulnerable if you had a major off & bike flipped.
Posted : 15/08/2012 10:28 am
I've got one of the Topeak drycases and the few times i've used it it's been fine.
For some stupid reason though they fit the back with a hinged belt clamp (does anybody still wear their phone on their belt!!??) which rattles constantly on anything but the smoothest of surfaces. I popped a bit of foam in the clamp though and that kept it quiet.
I have mine on the stem which i think would keep it fairly safe in anything but a massive off.
Posted : 15/08/2012 10:32 am
I have one from these guys that I use on my motorbike - works fine. http://www.ultimate-mobiles.co.uk/
Posted : 15/08/2012 10:34 am
I use a similar one to simon_g here:
[img] http://ecx.images-amazon.com/images/I/314ivAWewLL._AA300_.jp g" target="_blank">http://ecx.images-amazon.com/images/I/314ivAWewLL._AA300_.jp g"/> [/img]
£27.99 from http://www.amazon.co.uk/dp/B0057FJ41Y
Quick release (press button, leave mount on bike and phone case lifts off)
Secure (two double clips hold case shut)
Protective (phone is held inside a nice soft rubbery bit)
Rugged enough (dropped it a few times without issue)
Usable (all buttons and ports available through case)
Waterproof enough (happy to use it in pouring rain. Wouldn't actually use it underwater though)
I've modified mine slightly by disabling the rotating mechanism (with a bit of epoxy) and adding some inner tube rubber on the handlebar mount to stop it spinning.
Quite happy with it now.
Posted : 15/08/2012 10:42 am
does anyone use the lifeproof case and mount?
Posted : 15/08/2012 10:45 am
Thanks for the suggestions. They certainly seem more substantial than the eBay ones i looked at this morning.
Like the idea of the Amazon one where its hinged and locks the iPhone in.
Posted : 15/08/2012 12:27 pm
Yep, I think they're good. The case is great apart from the waterproof headphone adaptor which is a pain in the backside - it should be a scew-in stub, not an irritating flying lead as it is. Otherwise a quality bit of kit.
The bar mount's good too, though I wouldn't use it on a mountain bike, where you're likely to crash at some point. Easy to use quick release mounting system, 360? rotation for the phone, positive locking mechanism holding the phone in case.
Not cheap, but preserves the functionality of the phone, gives decent protection levels and isn't hugely bulky either.
Posted : 15/08/2012 12:48 pm
