iOS5 battery drain
[Closed] iOS5 battery drain
[#3259514]
since upgrading to iOS5 I've noticed my battery life is a lot lower.
A quick google found this thread on the subject, and possible short term fixes until it is sorted (presumably with iOS5.1)
[url= http://osxdaily.com/2011/10/16/ios-5-battery-life-fix-tips/ ]http://osxdaily.com/2011/10/16/ios-5-battery-life-fix-tips/[/url]
and this comment in particular seems a good one - iOS5 seems to have the GPS permanently on by default to check what timezone you are in
Hi,
I think I’ve found a cause of the battery drain. Believe it or not but it’s the System Service for setting Time Zone. If I go to Settings -> Location Services -> System Services and turn ON the “Status Bar Icon” option at the bottom, I can see the GPS is in permanent use. Disabling the “Setting Time Zone” option immediately stops it.
I’ve tried this on my dad’s iPhone 4s too. I suspect it’s an iOS5 bug.
All the best,
Alex
Posted : 19/10/2011 7:27 pm
Carry a spare battery...oh. 😉
Posted : 19/10/2011 7:29 pm
Thanks for this. Upgraded to a 4S on Friday and I thought the battery seemed worse than my ageing 3GS. sure enough, checked in settings a nd the phone was using GPS to set my time zone...
Posted : 19/10/2011 7:45 pm
Noticed this after I upgraded, even after switching it off battery life seems to have taken a bit of a hit.
Posted : 19/10/2011 7:51 pm
Ah, that's useful, I wondered why the GPS symbol was on even without any mapping 'ware running. And yes you can carry a spare battery. Amazon do one, around £22 and will fully charge an iPhone or iPad. Just plug in the cable. Then there's battery cases...
Much better than a removable lith ion battery that you have to carry in a case in case it catches fire because the contacts get crossed.
Posted : 19/10/2011 8:08 pm
it wasn't for me - I've just realised thats because the GPS icon thing in the status bar had been switched off after the upgrade - got it switched back on now
Posted : 19/10/2011 8:14 pm
Hmm odd it didn't seem to be showing the GPS icon on the status bar. Maybe the System Services don't - or maybe it just doesn't kick in much. Deactivated anyway.
Edit: ah it does when you activate that setting. Very odd.
Posted : 19/10/2011 8:27 pm
Graham S - go to Settings/ Location Services/ System Services - then scroll to the bottom. You may find (as I did) that the GPS Icon in the status bar has been deactivated (mine had)
Posted : 19/10/2011 8:33 pm
Yeah see it now. Ta.
Don't think that setting was "deactivated" BTW, as that setting didn't exist in iOS 4.
Posted : 19/10/2011 8:45 pm
