klumpy - you are correct 🙂
But Im quite happy spending my savings on shiny bike parts. I got far less when the money was in an ISA.
Its the best thing Ive done with any money Ive ever had.
I've read the Without Hot Air paper from start to finish.
Its clear that solar isn't the answer but it could make a very useful contribution.
A move to ground or air source heat pumps would help as well too.
Coal and Fission for the next 50 years until renewables can ramp and we have viable Fusion
If solar energy was that good we wouldn't need subsidies for it. It would've happened already.
Well not necessarily - sometimes you need economies of scale, and you can't get those without lots of take-up. So the public susbsidy is to get around this initial Catch-22. A good use of Government imo.
Klumpy, I am with you - and I am so far from being a communist. The whole concept of subsidising panels for reasonably affluent people by levying increased charges on the poorest is totally screwed up. Add to that the fact that the panels will take AT LEAST two years (and possibly much longer) to payback the energy cost of making the panel in the first place and its clearly got very little to do with reducing CO2...
No-one has talked about biomass yet as far as I can see.
As someone who works for a company that has to deal with a lot of poo, I see this is an entirely viable source of energy. Our largest poo factory is already generating around 9MW. That's just one waste water treatment works.
The food and stuff that goes in your green bin is also being used to generate electricity on a quite reasonable scale, the new plant at Widnes will produce around 4MW.
let's do some maths!
uk population = 60,000,000
let's assume that each household is 3 people, living in a house, with a roof that can present 10m^2 of usefull roofspace towards the sun.
lets assume that half of all households are suitable (some households are a flat)
finally, lets assume that each square metre generates an average of [s]1kw[/s] edit: 500W during daylight hours.
10,000,000 roofs, 200,000,000 square metres of solar panel, [s]100,000,000,000[/s] edit: 50,000,000 Watts of power generation.
that's [s]100GW[/s] edit: 50GW
from memory, the uk needs something like 70GW, so according to my vastly over-optimistic estimates, it [s][i]could[/i][/s] edit: couldn't work...
[s]now, how feasible is it?[/s]
i'm sure photovoltaics have their place, i'm not yet convinced that place is covering every roof in the uk.
Add in to the mix tidal, wind and ground source heat and the UK could easily* go the way of Germany and rid itself of nuclear altogether.
*Yes, the word easily is not entirely correct, but everything requires a bit of work doesn't it.
The gov response to all this is daft and short sighted. Logical thinking people stand no chance of changing that response, which is a shame.
Make the most of what you can now.
glasgowdan - MemberAdd in to the mix tidal, wind and ground source heat and the UK could easily* go the way of Germany and rid itself of nuclear altogether.
Germany still uses Nuclear power, they buy it from the French + Swiss.
let's do some maths
Why not read the link where someone has done the maths properly?
why not think for yourself?
i'm not being ar53y, i just like doing maths 🙂
(and, that link is where i got my 1000/500W value from)
it could edit: [s]couldn't work[/s]... provide 70% of a base load bassed on pretty rough and ready calculations; so let us assume that it could provide 35% of a base load. That is better than a kick in the bollox and could help take the edge off the ever increasing fuel bills that are shafting [s]the poor[/s] everyone pretty much.
alex222 - MemberEveryone is ready to jump up and down and say Photovoltaics, infrared hot water (hot water solar) onshore wind, offshore wind, tidal, wave, insert any form of renewable energy is useless. The only answer is coal and we may as well just deal with the rising cost of energy with no consideration for alternatives.
grum - MemberDo we have to have this straw man in every single thread about energy?
I'm guessing you don't understand what "base load" means in the context of power generation.
+1 to ahwiles, removing nuclear and using nuclear are 2 different things
This. It's incredibly socially unjust.
I note that nearly all the discussion is about supply side, yet we could do so much more to reduce demand. The subsidies for middle-class solar would save far more carbon if they were directed to proper insulation and efficient boilers instead.
Regarding how many power stations we would need, it's not binary. Use fossil fuels only for when it's dark and the wind's not blowing...
fasthaggis - Member
Most people are lazy and want to see some super fast return on the investment,so they can't be Rsd making the effort.The answer is more in educating about efficient use,rather than giving us more cheap energy.
Don't think most people are lazy or otherwise, how many people on the min wage, low paid jobs, renting or pensioners do you think can afford to install £10k worth of panels and then afford to maintain them? I know lots of people who fall into that category.
The polyester film used in panels has to be certified for 25yrs. I imagine all the other components used and that are not biodegradable will be the same. So in 25yrs or less when the first generation of panels have to be scrapped how will they be recycled? Yet another cost!.
The minimum amount of power a utility company has to provide.
Don't need to do dodgy maths to try to find a way to make GW generated by individual households balance GW required. Especially so when there needs to be some kind of source of power for when PV are not illuminated or bird dicers are not spinning on a calm day.
Might make more sense to use other means to reduce power requirements. Solar heating, ground source heating, etc.
I'm all for mini/micro nuclear in every home (just to spice it up a bit).
True, but did you know that French nuclear relies on having an export market? Because nuclear can't easily be turned up or down to match demand, exports and imports are the only way they can sustain such a high percentage of their generation from nuclear. That, and a shed load of hydro.
So how does solar provide 70% of that when it's dark?
it could edit: couldn't work... provide 70% of a base load bassed on pretty rough and ready calculations; so let us assume that it could provide 35% of a base load. That is better than a kick in the bollox and could help take the edge off the ever increasing fuel bills that are shafting the poor everyone pretty much.
except at night 🙂
I think that simply reinforces the point that Germany is still using nuclear - simply that not only do they locate their nuclear power stations away from their centres of population, they locate them in a completely different country.
You will all go round in ever frustrating arguments about what should be done vs what is being done.
In the end you will realise no Gov is going to do the right thing and not enough individuals will make a difference.
You then end up realising the most logical thing to do is make money for yourself out of the daft system.
*turns up heating as its free and a bit nippy outside*
So how does solar provide [s]70%[/s] of that when it's dark?
You got me; how does solar provide 35% of that when it's dark?
[url= http://www.energymatters.com.au/index.php?main_page=news_article&article_id=1593 ][edit]except at night[/edit][/url] 😀
You can't use panels on most buildings in the Dales. The National Park authorities want the Dales to keep their character right up until we are building nuclear plants and wind farms across the top of the hills and there is a tidal scheme on the Wharfe.
It's got to be a no brainier to fit things if you can afford it, you can appease you middle class consciences by purchasing a copy of the Guardian whilst employing a cleaner. Oh and drink a little champagne.
Always the problem when a gov term is ca. 5 years, and of those, 2 are when they can do radical stuff in a honeymoon period, 1 is mid term blues, and the last 2 are a combination of trying to get elected again or setting up the next govt to have a sh1t time if you're going to lose.
Using the German example above - Merkel cashed in on the Japanese tsunami and Fukushima issue to grab back a little bit more popularity, and to make sure no other party could do that for the elections which are later this year. Germany may have a lot of windmills, but they certainly don't provide the meat of the power generated.
zeee chermans are going for it and they think they can make it work, and I wouldn't bet againt them
[url= http://www.bbc.co.uk/programmes/b01q8mqh ]Costing the Earth - Berlin's Big Gamble[/url]
certainly an eye opening program - interesting how it's not big-gov and big-capital driving a lot of the development it's small/local groups. The down side is the eye-watering bills they're gonna have to pay for a few years, although if the Russkies turn the gas off they can still be warm.
Check out the table in this wiki article
[url= https://en.wikipedia.org/wiki/Renewable_energy_in_Germany ]Renewable Energy in Germany[/url]
Surely once the Russians turn off the power we will be grateful for any electricity at all.
Making this country as self sufficent as possible is not only so we can watch X factor it's about national defence.
We will end up doing whatever the Russians want or they won't give us any leccy. Ukraine anyone?
The 'without hot air' link - its interesting to see what the big chunks of consumption are; air flights, heating & cars.
Its fairly apparent that cars & flights in their present form will just get more and more expensive. I guess eventually people will be forced, economically, to start cutting back on travel.
Heating is a bit trickier, we like to not freeze. Time to stock up on woolly jumpers. Or build better insulated houses that don't leak heat & make good use of the sun.
PV by its nature is a direct current, as we sit on a grid designed exclusively for AC then surely the greater us of pv must mean greater use of switch mode dc>ac conversion and step up transformation to match grid voltage, this (imo) cannot be a good thing,it cannot therefore be viable except on a very small scale or limited to demands immediately in the vicinity of where it is produced ie: drip fed into the households mains via an inverter downstream of the meter if tariffs are to be collected.
This is a purely personal opinion and I apologise if it offends anyone.
alex222 - would you care to do the calcs to work out how much space you'd need for your molten salt battery to provide [s]70%[/s] 35% of the UK's baseload? Though given you're advocating solar panels on roofs, presumably you just put some molten salt storage under every house, along with the associated steam generator etc.?
Feel free to just suggest it's a problem we'll solve in the future if it helps.
If only Germany had the army of naysayers and people with a hard on for nuclear power we have in this country, then they wouldn't be falling for all this misguided hippy nonsense! 🙂
alex222 - would you care to do the calcs to work out how much space you'd need for your molten salt battery to provide 70% 35% of the UK's baseload? [url= http://www.energymatters.com.au/index.php?main_page=news_article&article_id=1593 ]Though given you're advocating solar panels on roofs, presumably you just put some molten salt storage under every house, along with the associated steam generator etc.?[/url]
My comment was based on some calculations that someone else did as in ahwiles did some rough calculations to say that pv could provide 50GW which is 70%. I know it is not the answer I just find it hard to believe that it doesn't go some way to helping out with the problem that we [i] humanity[/i] are currently faced with. I would hold my hands up and say it is not the answer and I am by no means an expert but surely combined with other sources of power it can go some way to alleviating fossil fuel dependency?
aracer - Member
alex222 - Member
Everyone is ready to jump up and down and say Photovoltaics, infrared hot water (hot water solar) onshore wind, offshore wind, tidal, wave, insert any form of renewable energy is useless. The only answer is coal and we may as well just deal with the rising cost of energy with no consideration for alternatives.grum - Member
What is the answer aracer? You seem to know wholesale what isn't the answer so presumably you also know what the wholesale answer is?
Was going to say it'd make more sense to build solar parks, but then the land they'd use are farm fields that are either sitting there doing nothing or would be fields that would have been useful for biomass.
Only need to build an apple orchard round the solar park to make it invisible to passers by, unlike bird dicers up on scottish hills.
Sounds a reasonable opinion to me based on what I know of electrical engineering.
Inverters can get to about 80% efficiency quite easily. I'm not sure how much more efficient it is possible to get, even at great expense.
However, running a few gadgets and gizmos from an inverter isn't a bad option, doing the route of Solar panel -> charge car type batteries -> inverter -> TV / fridge / etc.
Inverters are not much use for power appliances though, kettles, dryers, washers. A lot of those would be far better served by other (more efficient) power sources.
I've always been of the (uninformed) opinion that the embodied energy of a PV panel was a killer. Especially as it just moves the problem to the country of manufacture which is probably more polluting than the UK.
However, I've just been reading this report:
http://www.resilience.org/stories/2006-06-16/energy-payback-roof-mounted-photovoltaic-cells
Which concludes that realistic energy payback from a roof-mounted PV panel is approx 8 years (including dealing with the waste/pollution/etc).
This sounds hopeful to me.
Germany relies on electricity imports generated from various sources, including nuclear. But those who point to the French example of a very high percentage from nuclear need to remember that they are heavily reliant on exports and imports with other countries.
Just like nuclear. That should never have been given, and still being given, public subsidies.
Coal and gas get massive massive subsidies from the environment, paid for by the poorest in the world. Lets try to phase those out first shall we?
Given how many nutrients are in biosolids / garden waste, how much energy it costs to produce mineral fertiliser, and the fact that the world will run out of phosphorus (we can't make it from air like N fertilisers), i'd say it was pretty criminal not to be using biosolids et al. as fertiliser. Burning them's daft. But getting the best of both worlds out through biogas production, then reusing the residue as fertiliser makes a lot of sense.
Biomass grown for that purpose displaces food. I know what I'd prefer to feed - my family, rather than my car / tv.
If only Germany's army of hippies would realise that their nuclear-free utopia relies on French nuclear power
And French nuclear power relies on exports to Germany. What's your point?
Which was based on putting solar panels on every roof - or did you miss that bit?
Really, so why did you write "it could... provide 70% of a base load bassed on pretty rough and ready calculations; so let us assume that it could provide 35% of a base load." - if you know that it wasn't true? You do realise that you were the one who added "base load" to awhiles' calcs which didn't mention that?
Do you know that the solution to the middle east problem isn't to arm both sides with nukes and let them go at it? Good - let's know what the solution is then?
I'm not entirely sure whether you're still missing the irony of writing a load of hype suggesting people were claiming something they aren't right after grum's comment about straw men.
That between the two of them they have a healthy mix of nuclear?
I don't think anybody is suggesting every country should have as much Nuclear as France - simply that it is useful as part of the mix, and that France's excess goes to make up for those countries who have ideological objections to having such things on their own soil.
I was trying to make the point that an interconnected energy grid using a diverse range of sources is surely the way forward. Nuclear may be part of that mix.
Once we've done all we can to minimise consumption...
Trekster
Yup I get all that ,I was more having a go at the general attitude to energy saving and fuel use ,from people that do have a choice.
A lot of people want to keep on using the same levels of energy and fuel without the cost going up ,rather than trying to reduce their need for it.
As an example:
Look at the last time the tanker drivers went on strike and people were forced to car share and think a little bit more about the way they were driving. Plenty stories from mr and mrs amazed ,that they had magically saved money .
As for people that can't afford to invest in energy saving ,maybe landlords or local communities should go some way to making sure that buildings and services are up to a good standard.
Plus ,3 pages in and nobody has mentioned Hydro ,the forgotten resource .
My point is that without it, parts of Germany would be very cold and very dark. Whereas without Germany, parts of France would have a few less nuclear power stations. Also, Germany can hardly claim to be nuclear-free when it uses nuclear power.
What's your point?
Unfortunately, hydro tends to take up quite a bit of space, and also requires some quite specific topography - the most suitable of which is already in use.
