HTII bearing help
[Closed] HTII bearing help
@kaesae 🙄 - I am sure your bearings are fine - My point is whats the point of putting decent bearings into something that is badly sealed and lets loads of muck in and wears out bearings anyway - Yes yours may last longer but in mud 'n' the like? Perhaps its better to buy a BB thats better sealed and save yourself the grief?
Posted : 19/04/2010 8:09 pm
foxyrider - Member
Is that your super duper bearings Kaesae?
Are you sure that's your point foxyrider? Then perhaps you could explain the meaning of the above statement and the point of it?
The point is that if the bearings are properly weather proofed then it will compensate for the poor quality of the BB or other components.
Most manufacturers or distributers don't weather proof their bearings and why would they if they only last 1 year rather than 3 years they get to sell you three sets.
How many bearings have you actually analyzed because I have evaluated the condition and the cause of their failure of thousands of bearings.
Posted : 20/04/2010 10:10 am
You took it the way you did because you felt I was criticising you - was just a throw away comment - chill out dude 🙂
Posted : 20/04/2010 10:13 am
Oh what's wrong booboo is my argument much better structured than yours. Don't try and get out of answering the questions.
What is the point of the super duper bearings comment and how many bearings have you evaluated to determine the cause of their premature demise. What's the best way to avoid them either seizing or collapsing? to ensure they last as long as possible.
Posted : 20/04/2010 10:20 am
I just answered your question didn't I - did you just not like my answer?
Shall I make up another meaning to my comment then - Shall I say it mean't "I love your beaings Kaesae"? or "I hate your crappy bearings Kaease"?
The real meaning was that YOU call your bearings as the best bearings in the world - My comment was therefore mimiking you when you say they are the dog's whatsists? I have no experience of your bearings so I cannot comment on it. Maybe accept my comment for what it was?
Posted : 20/04/2010 10:30 am
What do we know about tribology and Hertz bearing theory?
Posted : 20/04/2010 11:26 am
Is that Hertz rent a bearing? 🙂
Posted : 20/04/2010 11:33 am
http://www.brammer.co.uk/uk_brammer_bearings.aspx
as good as anywhere to buy bearings?
Posted : 20/04/2010 11:51 am
This one is still going strong 😉
Posted : 20/04/2010 1:06 pm
Did you drill grease ports in your BB - cool!
Question: Do you still remove your cranks and service the cups to remove the crud?
Posted : 20/04/2010 1:08 pm
Fivespot it was him I mentioned in one of my earlier posts, couldnt remember his nickname, post the cutaway picture fivespot, and absolutely brilliant bit of modding, that really should be in production.
The grease should purge out past the lip seal taking the junk with it.
Posted : 20/04/2010 1:12 pm
As tinsy says, the new grease (one pump after crappy rides) purges out the old grease/muck. I use a light semi fluid grease, which not only causes less drag, but also keeps the lip seal lubed. Its the lack of grease on the lip seal which is the first failure point of nearly all the HTII BB's I have repaired/replaced, crappy water enters this point and quickly turns to rust when you put your bike away.
I also have my own theory on why the none drive side bearing always goes first. If you look at the sprocket side of your BB, it is well sheilded from a lot of crap thrown up by your front, whereas the other side is open to everything the front wheel can throw at it. Some will say that the preload on the bearing is the cause, but that preload nut pulls the other crank as much as it pushes the one its in, so preload should be equal accross both bearings.
Thease mods and my theorys are only based on my knowledge from working in industry for 30+ years. I don't claim to be any sort of specialist, I just enjoy tinkering.
Cutaway pic as requested 8)
Posted : 20/04/2010 1:35 pm
Top ****in bannana... I got a spare BB and some new cheapy bearings, would you do mine for me if I mark up the correct place for the grease fitting?
I do however have one question, what stops the plastic tube filling up with grease? Or cant the grease pass the bearing seal on that side??
Posted : 20/04/2010 1:42 pm
Yup my theory too 🙂
I presume its beacuse it a proper grease port so have to inject grease under pressure to open the port?
Posted : 20/04/2010 1:44 pm
Yeah I see that but, what after its into the bearing, if it can purge out crap to the outside does it also not purge into the plastic tube on the inside?
Answering my own question:- Looking at the cutaway again, it is the bearing seal keeps it in.
Posted : 20/04/2010 1:48 pm
Pace have a system for pumping grease through the bearings in their RC80BB
Posted : 20/04/2010 2:11 pm
yeah but the grease gun and adapter are both sold seperately, bit of a rip off if your paying £60 for the BB already
Posted : 20/04/2010 2:13 pm
So does Chris King, but its not as good as what fivespot has done just for a laugh... It looks like the Pace as the CK require some dismantling to grease them.
Fivespot, you considered getting this to market as a cottage industry?
Guess it was a much bigger deal when an XT bb was £40... but even so itS great.
Posted : 20/04/2010 2:20 pm
@fivespot I think that's called inventing. very nice would be great to see it in mass production.
@Foxy if I've taken the best bearings in the world and weather proofed them to be specific to outdoors use, how could they not be the best bearings in the industry?
Posted : 20/04/2010 2:25 pm
Some say on here a def no no as you damage the seal when removing and replacing for greasing purposes?
Posted : 20/04/2010 2:29 pm
fivespot - as the rear of the bearing is sealed, and there is no seal to force the grease into the bearing, Shirley all you are doing is filling up your bb shell with grease?
It'll come out the chainstay hole like on the old konas 😀
Posted : 20/04/2010 2:37 pm
I'm hoping the the Hope that has just replaced the Truvativ GXP in my bike will last long enough to justify the higher price. From what I've heard it's much better sealed and when the bearings within it do eventually go you can easily replace them. I had considered the Chris King until I found out how much the grease tool cost!
Posted : 20/04/2010 2:40 pm
cynic al, I had a design in my head once that did just that, sort of, replace the plastic tube with an alloy one, have a grease nipple in that, and a clearance hole on the BB shell to get to the grease fitting, you would fill the void between the new tube and the axle with a semi fluid lube like fivespot is talking about, would involve removing the inner bearing seal all together to allow it to flow.
Be a faff to fit as you would need to screw the grease nipple into the new tube after assembly, popping it through the clearance hole in the BB..
Would only be a few ml of lube, but would of course weigh a little extra.
Posted : 20/04/2010 2:52 pm
kaesae - Member
WTB came up with the idea in the 80s!
Kaesae, how do you "weather-proof" your bearings? Unless you upgrade teh seal, all you can be doing is filling them with grease?
Posted : 20/04/2010 2:53 pm
Was that directed at me al? My idea was inspired bike really old bikes with loose ball BB, some had a flap on the BB you could swivel out of the way to drop some oil into it..
Posted : 20/04/2010 2:56 pm
Tinsy....sorry for the delay, got dragged around Tesco for the last hour 😥
If you look at the lower pic, you will see a small cutout I made in the side of the bearing and seal. When this is lined-up with the grease port when fitted, most of the grease goes into the bearing 😉
I recently stripped this BB after over a years use, and there was very little grease in the plastic tube. This was a used BB that had started to feel a liitle bit rough when I decided to do this mod. Although there is still a very slight roughness, this has been the same from day one, and I don't see why it should'nt stay working for many years.
Tinsy, I could Modify your BB. Just out of interest, are your replacment bearings 6mm wide as per originals, or are they 7mm like many of the aftermarket ones ?
As for marketing something like this, the main problem would be the position that the grease port ends up ! On my BB I marked the place I wanted the ports to be with the BB in place, then removed to do the tinkering bit 😉
Posted : 20/04/2010 4:17 pm
@Cynical-al PASS.
Posted : 20/04/2010 8:34 pm
cynic-al, please don't call me Shirley. The answer to your question is listed above 😉
Posted : 20/04/2010 9:06 pm
I also enjoy the tinkering aspects of life and have shamelessly plagiarized fivespot (thank you old boy) and modified the cups on our 3 bikes. In my case I turned the bearings round so that the open side faces the plastic inner tube and the sealed side faces the outer plastic shield. In this way the open side of the bearing can receive the greasy goodness where it's needed.
I also drilled holes in the BB shell and sealed up the rear facing seatpost slots with silicone mastic.
I got the grease fittings shipped over from America BTW.
Posted : 20/04/2010 9:21 pm
Cynical al if there is grease filling up a space then water will not be able to be in or shall we say fill up that same space. YES or NO grease and bearings is good water and bearings is bad?
Posted : 20/04/2010 9:52 pm
Fivespot ta - Shirely I should get that now.
Kaesae - so you fill the bearings with grease? That's what I do too! I don't call it weatherproofing though.
Posted : 22/04/2010 9:52 pm
Page 2 / 2
