Hope Pro rs4 hub he...
[Closed] Hope Pro rs4 hub help please
Pro rs4 centre lock straight pull. How do I get the end caps off so I can tighten down the centre lock disc. Can’t fathom it out at all. Not found anything on Google.
Posted : 17/11/2017 10:04 pm
Do they not just pull off like on all other Hope hubs?
Posted : 17/11/2017 10:15 pm
It doesn’t seem so (it is possible I am being a pansy) the google search shows the pro 3 needing two 5mm Allen keys each end but again not happening on this pro 4 rs
Posted : 17/11/2017 10:19 pm
Can't remember any Hopes using Allen keys, they usually just pull out like Simon suggested. Some used to use circlips on the 20mm adapters. Are you sure you need to remove them to fit the lockring? How will you put them back on again once the lockring is fitted?
Posted : 17/11/2017 10:23 pm
Thank you sdb and dtf - I am a pansy!!!! Bit of a wiggle and pulled straight off 🙂 - with the cap on my cassette tool would not drop down enough to clear the end cap and tighten the disc rotor.
Posted : 17/11/2017 10:27 pm
Yes, the Pro 3 SP did have a [url= ]threaded tube[/url] on the QR adapter that needed undoing.
On the Pro 4 it looks like the caps should just pull out, according to [url= http://www.hopetech.com/wp-content/uploads/2016/10/Pro-RS4-CL-Rear-Hub-Assembly.pdf ]the diagram[/url].
Maybe you need the [url= ]through axle CL lockrings[/url]?
Posted : 17/11/2017 10:28 pm
Cheers all 🙂
Posted : 17/11/2017 10:31 pm
