hope brakes...rattl...
[Closed] hope brakes...rattling lever - how do I solve...
[#771908]
so I thought it was just because my mono mini levers were getting a bit long in the tooth, but just bought some more off the classifieds and they rattle as well!
any thoughts on how to solve it?
ta
Posted : 10/08/2009 9:41 am
1. Check that the pivot bolt is tight (dur!)
2. Replace the plastic bushes in the lever
Posted : 10/08/2009 9:43 am
Are they the old mini levers? If so it is probably the brass barrel.
Posted : 10/08/2009 9:55 am
Good point - is the lever actually rattling or is the just play before the brake engages? If the latter, it's the brass barrel as suggested.
Posted : 10/08/2009 10:03 am
no - they are the mono levers - but yes, they do have the brass barrel, I'll go and have another look...
Posted : 10/08/2009 10:15 am
Brass barrel is a key culprit. Somethimes they also ovalise the hole in the lever so may need new levers too, but a new barrel should sort it out.
Posted : 10/08/2009 11:11 am
